I purchased a video through iTunes and when I checked the info on the video with mediainfo I can see that it has 2 video bitrates:
My issue is that when I used M4VGear to remove the drm it could only access that lowest quality video. Is there a way to access the higher quality video? I want to burn this to dvd so I need the highest quality video if possible.
	Open the mp4/m4v with mkvtoolnix, remove one video track, save as a new mkv. Convert it.
 And I hope you are ONLY ripping itunes that you have bought....not any rental.
 edit: But the other video track details doesn't look ordinary video....Last edited by Baldrick; 9th Dec 2016 at 03:52.
	Yes It's a paid for download (Whitney Houston Live: Her Greatest Performances). $12.99 for it. It wasn't available to rent.
 HmM...I hope it is. I will try the programs you suggested and see what happens.
	The video only has one video stream. The second stream that you think is a higher bitrate video is only a still picture. Look at the frame rate and codec. It is a jpeg file, possibly album or cover art, or a still image that displays when the audio plays without video.
	Also you're probably misinterpreting the bitrates. The video bitrate is being displayed in kb/s but the jpeg is being displayed in b/s, so the displayed video bitrate is much higher, although I'm not sure why a still image would display as having a bitrate. It's possibly something specific to the itunes format (mp4?) I don't understand.
	You all were right. It was just a still image. Nothing watchable. I think I was just the way they encoded that particular video. Possibly something to do with copy protection. I've purchased several videos from iTunes and this is the only one like that. Oh Well. I got the protection removed so I'm ok. Thanks for clearing things up for me.
  Highest Quality Video EditingBy lomaidala in forum EditingReplies: 70Last Post: 25th Jul 2023, 18:55
  Capturing PAL at highest quality possibleBy luckyo in forum Capturing and VCRReplies: 5Last Post: 4th Nov 2015, 08:27
  Highest quality DVD ripperBy dking023 in forum DVD RippingReplies: 5Last Post: 25th Aug 2015, 09:02
  which video streaming has the highest video quality?By jgy2001 in forum Video Streaming DownloadingReplies: 9Last Post: 11th Nov 2014, 13:56
  MKV to BLURAY highest qualityBy Mikey0124 in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 16:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
