Looking for a good software to compress BD Remuxes (untouched bit rate etc so full BD quality - i am sure you get what i mean) down to much smaller MKV's for consumption a Nook HD+
The Nook has a 9" screen and can play 1080P.
Goal is to get a good number of remuxes onto an microSD card - SD card is 64GB.
I am a newb to this so you guys know a whole lot more then me, so maybe you could recommend an approximate bitrate to aim for? I would like to keep file sizes to 2GB or a bit less, maybe 1.5GB. I would think AC3 audio for compatibility?
I know there are many programs to do this - my head is aching reading about them. I just dont know which one is a great one never having used them before.
So, whaich program will do what i want ?
Results 1 to 13 of 13
Thanks sneaker.
WOW - go back to MP4 container. I thought MKV was the almost defacto standard now - but then again, as you say, all sorts of tablets and android phones will play MP4's. So that all makes sense. -
Well, when using Android players like VLC or mx player you can also play almost anything. But MP4 is almost always supported. MP4 and MKV are both good containers. Both can hold H.264 video and have low overhead. So it doesn't really make a difference for you unless you want to insert multi-channel Dolby or DTS audio or embed subtitles. In that case I prefer MKV as well.
Some good advice there, thanks again.
I knew i came to the right place to ask.
Cheers and beers -
Are all these programs basically the same? Ie, use the same encoding engine ?
MKV Compression to a smaller MKV or MP4
By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 11:56 -
Compress/convert a DVD movie to (smaller) MKV, or similar
By dogdad in forum DVD RippingReplies: 5Last Post: 31st Aug 2016, 13:28 -
Remux dvr-ms (or WTV) to MKV
By Ramias in forum Video ConversionReplies: 9Last Post: 6th Oct 2013, 15:48 -
Bluray remux to .ts or .mkv?
By Mr_X2012 in forum Blu-ray RippingReplies: 7Last Post: 4th Jan 2013, 13:46 -
Compress videos from FRAPS into smaller files-sizes
By torchi12 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2012, 21:38
