I have some videos. Working example is my 720x576 video with the header telling to playback the video in 1024x576. It works. But when I change the value the video will be displayed in the same resolution, no matter what I type. I also haven't forgotten to save the header after editing it. Whats the problem?
Your video decoder might only be using the video bitstream value, not the container value. Solutions:
- use LAV Splitter and LAV Video and set them to prefer container over video bitstream AR (should be the default)
- use Haali Media Splitter
Since Haali is not developed anymore I recommend LAV. You may need to run a filter tweaker to make WMP use LAV.
There are also options to remove or alter the bistream ar info, at least for h.264.
- in mkvooltnix: --engange remove_bitstream_ar_info
- http://forum.doom9.org/showthread.php?t=152419 (special ffmpeg build, not updated, experimental) -
I got it working with DVD Patcher. The problem was in the MPEG header and not in the MKV header. I had to extract the MPG file from the MKV with MKVExtractGUI-2 and in DVD Patcher I changed the aspect ratio to 16:9 and "Patch: Entire file". Here's a thread that helped me: https://www.makemkv.com/forum2/viewtopic.php?f=7&t=6192. Look at the last post.
Avidemux: changing width and height don't change video-size
By Tedbax in forum Newbie / General discussionsReplies: 5Last Post: 12th Mar 2016, 15:18 -
how to change the pixel height and width of mkv?
By speedyallan77 in forum Blu-ray RippingReplies: 3Last Post: 3rd Sep 2013, 13:59 -
MKVToolnix - cropping or changing display & width height
By wacus in forum Newbie / General discussionsReplies: 9Last Post: 6th Jul 2013, 14:30 -
Getting exact pixel and display width in an mkv using Handbrake
By skinney6 in forum Video ConversionReplies: 6Last Post: 12th Mar 2012, 12:46 -
Shaving 1 or 2 pixels off an mkv (pixel and display width)
By skinney6 in forum EditingReplies: 2Last Post: 11th Mar 2012, 11:06
