    Apr 2002
    London
    I'm using roxio videopack5.1
    i can convert the vdieo no probs, but i can't get any audio
    i've tried using the .avi as the audio & video source, but when it has converted into an mpeg there is no sound
    i've tried ripping the .wav from the .avi ( demultiplexing the avi and converting the new avi into an mpeg), which will play fine in mediaplayer, but after i convert it into a .mpa and try to multiplex it into the .mpg i brings up an error?
    anyone got any idea's?
    p.s. i'm a n00b
    cheers for any help
    laterz
    Apr 2002
    Saginaw, Michigan
    Download VirtualDub open it.... click File Open Video File... Select movie your looking for..... then click open... Scoll over to Audio... Scroll down too Full Processing mode and click dat... Then scroll back up in Audio too Conversion.... In sampleing rates click 44100hz and press ok.... go back into file and scroll down to save file as wav.... then click start... this will sav da audio to your computer as a wav file.....
    Use Tmpenc to merg your Audio and video together to get a output... that should work.
