The Kaby Lake Asrock Beebox supposedly has a usb 3.1 gen 2 port. Is there anyway to use this specific port with a usb capture card like the magewell for 1080p60 capture?
https://www.superbiiz.com/detail.php?name=MB-BS7100U&c=CJ
You would need an special USB adapter cable to use a USB 3.1 port with USB 2 or 3 and
if the Magewell is USB 3.0, it would likely operate at 3.0 speed. No real advantage.
The USB 3.1 connector is about the size of a mini USB connector and can work rightside up or upside down.
Chinese copies - Magewell XI100DUSB
By david151 in forum Capturing and VCRReplies: 6Last Post: 15th Aug 2017, 12:02 -
Magewell Chinese copy - strip down with pictures
By david151 in forum Capturing and VCRReplies: 16Last Post: 15th Jan 2017, 14:25 -
Kaby Lake i7 7700k "reviewed"
By sophisticles in forum ComputerReplies: 1Last Post: 1st Dec 2016, 16:27 -
Magewell Pro Capture HDMI 5.1 Aduio
By BlockABoots in forum Capturing and VCRReplies: 14Last Post: 24th Nov 2015, 13:51 -
Subs work in VLC but do not work in the DVD Player through USB
By faithhealer in forum SubtitleReplies: 4Last Post: 1st Jul 2012, 21:40
