I've heard it can be done, I was tinkering with it.
This is what I have so far:
LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\ffms2.dll")
Import("C:\Program Files (x86)\AviSynth\plugins\FFMS2.avsi")
AudioDub(FFAudioSource("d1.mp4"),FFVideoSource("d1 .mp4",fpsnum=30000, fpsden=1001,threads=1))
AddBorders(550,0,0,0)
With the borders, that puts the video on one half of the screen. I just don't know exactly how to insert an image or another video to play alongside it.
And
http://avisynth.nl/index.php/StackVertical
http://avisynth.nl/index.php/Overlay.
For example:
Or picture-in-picture:Code:v1 = WhateverSource("file1.ext") v2 = WhateverSource("file2.ext") StackHorizontal(v1,v2) # must be same height for StackHorizontal, same width for StackVertical
Code:v1 = WhateverSource("file1.ext") # big video v2 = WhateverSource("file2.ext") # small video Overlay(v1, v2, x=0, y=0) # Overlay small video at top left of big videoLast edited by jagabo; 2nd Dec 2016 at 12:39.
Yes, it's possible, easy even. Formats not matching usually refers to color space. If your video is YV12, so must be your picture. For example:
v2 = ImageSource("Picture.bmp").ConvertToYV12()
or:
v2 = ImageSource("Picture.bmp",End=1000).ConvertToYV12( )
where 'End' refers to the number of frames you want the picture to last (same as the video?).Last edited by manono; 2nd Dec 2016 at 21:40.
That works as well, except for I was testing different images until I used one that got an error:
"Cannot convert if height isn't mod2"
or:
where 'End' refers to the number of frames you want the picture to last (same as the video?). -
Your height has to be divisible by 2. RGB doesn't require it but YV12 does. You can crop away one row of pixels or add a row of black. Something like this:
v2 = ImageSource("Picture.bmp").Crop(0,0,0,-1).ConvertToYV12()
Multi split screen with Avisynth...
By pippas in forum EditingReplies: 3Last Post: 15th Jun 2016, 09:45 -
AviSynth - combine/split screen of two video files
By kj1983 in forum Newbie / General discussionsReplies: 10Last Post: 27th Feb 2014, 21:53 -
Split Screen?
By bencolin in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2013, 16:35 -
Using VirtualDub and AviSynth to make a split/PiP movie
By WebMaximus in forum EditingReplies: 18Last Post: 22nd Jun 2013, 07:57 -
Is it possible to split Avisynth output to 2 instances of X264?
By ndjamena in forum Video ConversionReplies: 4Last Post: 25th Mar 2013, 08:50
