I've got a video from torrent that is 95.3% downloaded. It won't download further unless a seeder comes on-line (not likely).
The video is 80 minutes, so simple math says that about 4 minutes of the video are missing. I know from past experience that the missing part likely will be split into several (approximately) one minute parts, randomly distributed throughout the video.
I played the first few minutes of the video with vlc and didn't run into any problems. Obviously, though if I played the video further, it would eventually freeze when it comes to a missing part.
My question is:
1) Are some software players better than others when dealing with this kind of situation. If so, what software player is best?
2) Is there some kind of software that will automatically delete the missing parts, then join the remaining sections to form a video that will play through with any software player?
You could try opening it with MKVMergeGUI and remuxing it as a new MKV. Checking the log file for warnings might even tell you where the missing bits are, but with any luck it'll output a file most players will play from start to finish, although there'd still be likely to be sections where video isn't decoded correctly due to missing information. You can only try.
My experience has been that It really depends on what format it is. FLV will play with potplayer for example and skip the missing parts. MP4 will not play on any player I know until it is finished because of the way all parts (atoms) are inter-related to each other. Other formats will be possible and not also.
Python scripts that auto encode Film downloaded from torrent
By innosia in forum Video ConversionReplies: 1Last Post: 19th May 2014, 07:30 -
Some general questions about blu-ray ripping
By Plecto123 in forum Blu-ray RippingReplies: 21Last Post: 31st Dec 2013, 11:45 -
I have some questions about video in general.
By paddlepop in forum Newbie / General discussionsReplies: 3Last Post: 16th May 2012, 15:20 -
When youtube video is downloaded, what quality is downloaded?
By Haopengyou in forum ComputerReplies: 3Last Post: 13th May 2012, 03:46 -
downloaded torrent avi video ENLARGES with dvd authoring??
By jbitakis in forum Authoring (DVD)Replies: 34Last Post: 22nd Dec 2011, 13:29
