Page 2 of 2
FirstFirst 1 2
Results 31 to 39 of 39
    Jan 2014
    Slovakia
    Thank you.
    It's too much...
    So, can you help me to find cheap videocard for PCIe x16 (2.0 or 3.0) with support 3 independent monitors? This will be my choice.
    Thank you very much.
    Miro
  2. I would go for http://www.sapphiretech.com/productdetial.asp?pid=E2085038-1F14-453C-AB2B-87227C599B44&lang=eng - should be around half of price of the board you provided - GTX 750 Ti is twice faster in GPGPU and 3D, has twice more memory but... it is also twice more expensive... for 2D display cheaper board may be more suitable.
    Jan 2014
    Slovakia
    Card you write about allows only 2 monitors at once.
    I found cheap (55 € only!) video card with 3 monitors support for PCIe 2.0: EVGA GeForce GT 720 2GB DDR3
    Please check it and if you'll find any problem please let me know.
    Here's link: http://www.evga.com/products/Specs/GPU.aspx?pn=d156fe1e-ebcf-4060-8987-c00945a11f65
    Thank you.
    Miro
    Aug 2006
    I was thinking of suggesting a video card with that GPU (GT 720) as well, but all that I found were passively cooled. I don't know if passive cooling is sufficient if you are running 3 independent monitors. You might be better off if you buy a video card with a fan.
    Also, most video cards take up 2 slots now, even the less expensive models. Will installing such a card block one of the PCI-e x1 slots that you are using?
    Jan 2014
    Slovakia
    Yes, there is written about 2 slots - currently my card is placed so, that one PCIe x1 unaccessible, so no matter, if 2 or 1 slot.
    Miro
    Aug 2006
    I didn't find an inexpensive, relatively recent graphics card with a fan where the card supports 3 monitors.
    This is the closest that I came to that goal: http://www.gigabyte.com/PRODUCTS/product-page.aspx?pid=6001&dl=#ov
    There are versions from EVGA too.
    http://www.evga.com/products/productlist.aspx?type=0&family=GeForce+700+Series+Family&chipset=GT+740
  7. Originally Posted by MIRKOSOFT View Post
    Seem you are right - sorry - i search for eyefinity and it was listed as supported... - my fault...
    Seem to be ok - however i focused on something with GDDR5 (memory bandwidth) - NVidia cheap cards using ordinary DDR3 memory... but anyway 55E look better than 130.
    http://extremecomp.ekatalog.biz/detail/GIGABYTE-GT730-1GB-64-aktiv-D-H-Ds-D5/402302
    http://extremecomp.ekatalog.biz/detail/Sapphire-R5-230-1GB-64-pasiv-D-2xDP-D3/438685
    http://extremecomp.ekatalog.biz/detail/GIGABYTE-GT740-1GB-128-aktiv-2xD-H-Ds-D5/363186
    http://extremecomp.ekatalog.biz/detail/GIGABYTE-GT740-2GB-128-aktiv-2xD-H-Ds-D5/363185
    First two support 3 displays, two second support 4 displays.
    Aug 2006
    Some GT 730 cards only support connecting 2 monitors.
    Jan 2014
    Slovakia
    Ok, thank you all.
    I listed some, my decision is EVGA GeForce GT 720 2GB DDR3.
    Without your help I couldn't find any solution.
    Thank you all.
    Miro
