I learned about using the source code to find video links which can be downloaded via ffmpeg. I was wondering if it was possible to create some sort of batch script to automate the downloading portion at least. I know I can create a batch script for local videos that need to be converted, but I failed to find any information for links.
For example, I have a series of links in a .txt file:
Within Videos.txt:
Is there any way I can create a batch script to automatically download those in ffmpeg? What if I go one step further and change the contents within Videos.txt to include the ffmpeg commands:Code:http://wpc.8c48.edgecastcdn.net/038C48/SV/480/FTLJPN0217/FTLJPN0217-480-,750,1500,2000,2500,4000,K.mp4.m3u8?9b303b6c62204a9dcb5ce5fdc107bb41bd0500a8a36f8ab8622e9bc76c6ad4c2e435cef60ddb0ff04f800a014db195260966d7c14777388e3a77e7ada377fa4fc7f528ca95d147dd535dcf579cff9d2a334f8565d2ea65cfc281a12a10" http://wpc.8c48.edgecastcdn.net/038C48/SV/480/FTLENG0166/FTLENG0166-480-,750,1500,2000,2500,4000,K.mp4.m3u8?9b303b6c62204a9dcb5ce5fdc007bb4104d2360e7fab15f96cf6e5f34fe40c97f9d77ed35d64ac44cdfba5bcef4bb99ab842e14b6800ed2db18deb6b01c11c4b408ce89418866e57aa2375fba6a9fe77e6eacc0c3f8880c22d376a96"
Or is this something that I should be doing manually (which is possible and not a problem, but I'd prefer leaving this overnight or something).Code:ffmpeg -i "http://wpc.8c48.edgecastcdn.net/038C48/SV/480/FTLJPN0217/FTLJPN0217-480-,750,1500,2000,2500,4000,K.mp4.m3u8?9b303b6c62204a9dcb5ce5fdc107bb41bd0500a8a36f8ab8622e9bc76c6ad4c2e435cef60ddb0ff04f800a014db195260966d7c14777388e3a77e7ada377fa4fc7f528ca95d147dd535dcf579cff9d2a334f8565d2ea65cfc281a12a10" -c copy S04E42.mkv ffmpeg -i "http://wpc.8c48.edgecastcdn.net/038C48/SV/480/FTLENG0166/FTLENG0166-480-,750,1500,2000,2500,4000,K.mp4.m3u8?9b303b6c62204a9dcb5ce5fdc007bb4104d2360e7fab15f96cf6e5f34fe40c97f9d77ed35d64ac44cdfba5bcef4bb99ab842e14b6800ed2db18deb6b01c11c4b408ce89418866e57aa2375fba6a9fe77e6eacc0c3f8880c22d376a96" -c copy S04E16.mkv
Thank you for your help!
Results 1 to 1 of 1
How to download all youtube videos listed in a .txt file
By Username2013 in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Mar 2016, 16:03 -
Can I get a little help with an ffmpeg script/batch file?
By Iced Coffee in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2015, 01:56 -
batch to extract - with ffmpeg - (initial)timecode to a .txt file
By marcorocchini in forum Newbie / General discussionsReplies: 41Last Post: 20th May 2014, 14:55 -
can ffmpeg directly type a .txt file with only timecode data?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2014, 16:49 -
Need help learning how to pull out stream links to create a .strm file
By cnmsales in forum Video Streaming DownloadingReplies: 0Last Post: 22nd Apr 2014, 00:46
