As above. And should it be used at all in most burns.
thanks
It will enable slow burning when needed but if the disc itself has defect errors then nothing will help.
Consult the Book of Knowledge!
(wikipedia)https://en.wikipedia.org/wiki/Optical_disc_recording_technologies#Buffer_underrun_protection
A buffer underrun occurs during recording if the supply of data to the recorder is interrupted before the write is complete. Software typically moves the data to be recorded into a buffer; underrun occurs if the recorder processes data in the buffer faster than the software reloads it.
DVD+R, DVD+RW and the recordable Blu-ray formats are immune from buffer underrun as these discs contain technology that allows the recorder's write mechanism to precisely locate the end of the recorded track and to seamlessly carry on from where it left off. Many disc authoring utilities 'grey out' the buffer underrun protection option when these discs are being written
Enabling Thumbnail Previews For MP4 Files
By jdvideo in forum Newbie / General discussionsReplies: 14Last Post: 1st Jul 2016, 00:25 -
DVD burn speed too slow problem and best storage options
By friendly_jacek in forum MediaReplies: 3Last Post: 15th Sep 2015, 10:43 -
DVD Architect and slow Blu-ray burn. WOW!!!!!
By ingeborgdot in forum Authoring (Blu-ray)Replies: 20Last Post: 14th Feb 2013, 11:01 -
blueray movies without blueray burner
By piano0011 in forum Blu-ray RippingReplies: 7Last Post: 31st Jan 2013, 00:45 -
DVD burn runs too hot, how to slow down reading the source disk
By loninappleton in forum DVD RippingReplies: 6Last Post: 28th Apr 2012, 09:31
