  1. lets say that from frame 0 to 34067 i want to use like 5 filters and then from 34068,34314 a different one and then join them
    what is the easiest way to do it?
    EDIT:
    source=Mpeg2Source("D:\VIDEO_TS.d2v", CPU2="ooooxx").TFM().TDecimate(Mode=1).ColorMatrix (mode="rec.601->rec.709").ColorYUV(cont_y=5, cont_u=-60, cont_v=0,gamma_y=-30)
    a=Trim(source,0,34067)
    b=Trim(source,34068,34313)
    c=Trim(source,34314,0)
    a = a.Hysteria(strength=6.0, maxchg=26, lowthresh=15, highthresh=20).McTemporalDenoise(settings="high"). nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720).Hysteria(strength=5.0, maxchg=28).Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3).nnedi3_rpow2(2, cshift="spline36resize", fwidth=1920, fheight=1080).Blur(1.0)
    b = b.nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720).nnedi3_rpow2(2, cshift="spline36resize", fwidth=1920, fheight=1080)
    c = c.Hysteria(strength=6.0, maxchg=26, lowthresh=15, highthresh=20).McTemporalDenoise(settings="high"). nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720).Hysteria(strength=5.0, maxchg=28).Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3).nnedi3_rpow2(2, cshift="spline36resize", fwidth=1920, fheight=1080).Blur(1.0)
    a+b+c
    its this ok ? (a and c are one line it just doesnt fit here)
  2. Yes, it's OK - but I suggest you organize your code into functions, like this:
    TFM
    TDecimate(Mode=1)
    ColorMatrix(mode="rec.601->rec.709")
    ColorYUV(cont_y=5, cont_u=-60, cont_v=0, gamma_y=-30)
    return
    \   fa.Trim(0, 34067)
    \ + fb.Trim(34068, 34313)
    \ + fa.Trim(34314, 0)
    function fa(clip C)
    	C
    	Blur(1.0)
    	return Last
    function fb(clip C)
    	C
    	return Last
    #function fc(clip C)
    #	C
    #	Hysteria(strength=6.0, maxchg=26, lowthresh=15, highthresh=20)
    #	McTemporalDenoise(settings="high")
    #	nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720)
    #	Hysteria(strength=5.0, maxchg=28)
    #	Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3)
    #	nnedi3_rpow2(2, cshift="spline36resize", fwidth=1920, fheight=1080)
    #	Blur(1.0)
    #	return Last
    Putting filters on separate lines makes them easier to comment out for testing.
    You will also get better error feedback: the line number will usually point to the exact filter that is causing the trouble.
    Note use of "\" for line continuation, and the implicit Last variable.
    After re-formatting the code this way, it became obvious that fa() and fc() were identical, so fc() was commented out and fa() called twice.
