    Apr 2002
    Saginaw, Michigan
    I here it all da time from people dat I need to use TMPG to convert a wmv file. Well I've looked for a "how to" but couldn't find any on da matter. If you know how to convert a WMV file into a different format please help. I'm looking for some instructions. Thanks Imp.....
  2. Try changing the priority for your direct show filter in TMPGEnc
    do this.....
    go under Options--Environmental Setting--VFAPI Plug-in and set your Direct Show Filter to priority 0 (zero)
    that *should* take care of it
    your pal,
    Stinky
