  1. Hi everyone!
    Just from one day to another, i couldn't use my Arrow Keys anymore. I really need them to adjust the transitions of my videos to the music. The problem seems to be in the Project-File. If I open up the same project on another PC, it doesn't work. If I create a new project, it works. Reinstalling Premiere Pro didn't fix my problem ether.
    See screenshot:
Name:	Premiere Pro Problem.png
    Is there a way to set project settings to default? Or does anybody know how to fix my problem?
    Thanks in advance and cheers,
    Xyron
  2. Creating a new sequence solved my problem (isn't the proper solution tho).
    Once I realized that the numbers displayed on my screenshot were "Audio Numbers" I was able to find this post, which might help somebody out (didn't help me tho):
    https://forums.creativecow.net/thread/3/964819
    Still really annoying. If you have effects like "Warp Stabilizer" you have to set them again.
