there is this guy i know nothing about
all he does is upload anime series he upscales to torrent sites
he never comments for some reason (maybe he doesnt understand english, he is Chinese so maybe he hangs at other chinese websites ) (if some one here knows chinese and could help me dig something on him ill be glad , i have a bit more information on them\him)
he doesn't rip the DVD himself
he just uses the 480p rips other people upload
here are some examples (one i a regular 480p rip the second is his upscale 720p)
http://screenshotcomparison.com/comparison/192192
http://screenshotcomparison.com/comparison/192194
also he releases them pretty fast...
how does he make the lines look so much better?
i tried every thing with sharp() and aWarpsharp() its not just this...
the reason i am asking is because i want to know how he did it and use it on some other shows i have.
				Results 1 to 21 of 21
	He's probably using a dehalo_alpha(), a line darkener (fastlinedarken, fastlinedarkenmod), and an antialiaser (santiag, aaa) too. And upscaling with nnedi3.
	zanzar, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules: Thanks,Try to choose a subject that describes your topic.
 Please do not use topic subjects like Help me!!! or Problems.
 Moderator redwudz
	I suspect he's using Hysteria() too. That gives line darkening and thickening.
	SetMtMode(5,4)
 v = LWLibavVideoSource("d:\4.mp4")
 a = LWLibavAudioSource("d:\4.mp4")
 AudioDub(a,v)
 ConvertToYV12()
 ColorMatrix(mode="rec.601->rec.709")
 fastlinedarkenmod()
 santiag()
 nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720)
 and it looks like dehalo alpha blurs all the barely seen lines and makes it worse (is there a way to restore them)
 this is the end result https://forum.videohelp.com/images/imgfiles/kqdHGdM.jpg
 far from his https://forum.videohelp.com/images/imgfiles/v6t4f55.jpg
 is this really this hard to imitate this? i think my knowledge on this subject is just limited
 here is another exmaple of other series
 http://screenshotcomparison.com/comparison/192224 i know he uses other people rips because some times a problem that appear in some ones rip also appear in his version (defects that cannot be removed with filters)
 it looks like there is no mistakes there just a better quality and thats it -perfect-
 is it really that hard to archive it? even with your knowledge? you basically answer every question on this sub with easeLast edited by zanzar; 29th Nov 2016 at 13:44.
	I would give a chance to https://en.wikipedia.org/wiki/Dilation_%28morphology%29 first (prefer to oversample input video and after this apply dilate kernel) - it will be good to remove noise and distortions/artifacts from signal - perhaps with help of http://www.compression.ru/video/cartoon_restore/index_en.htm or similar filter.
 sure
 i created a rar with 3 different samples from different shows one 480p raw and the other is his 720p version
 you can actually see the "filtering style" in all of them, "buttery" clean lines , no noise and it looks very nice to the eye (its like he uses the same script for all of them) compared to the original.
 the general improvement in quality varies from show to show
 thanks for trying to help
 fixedLast edited by zanzar; 29th Nov 2016 at 18:15.
	No need to sorry - it was ad hoc idea - you can give a chance to ffmpeg (it is quite fast) bellow is example for ffplay to perform this kind of processing while watching video.
 Second link was related to VirtualDub (where i would recommend modern fork https://sourceforge.net/p/vdfiltermod/wiki/Home/ ) but Avisynth is able to use Virtualdub filters, ffmpeg is able to use avisynth scripts too - there is many combinations you can use - sometimes ffmpeg or virtualdub can be faster/better sometimes avisynth can't be replaced...Code:@set vproc="pp=ac/dr,hqdn3d=2,scale=iw:ih:sws_flags=neighbor:sws_dither=none:in_range=1:out_range=1,xbr=2,erosion=threshold0=65535:threshold1=0:threshold2=0:threshold3=0,format=pix_fmts=yuv420p,zscale=d=ordered:f=spline36:r=full:w=iw/2:h=ih/2" @ffplay.exe -hide_banner -color_range 2 -loop 0 -i "%1" -an -sn -vf %vproc%
 And i need to apologize - i wrongly named erode filter as dilate - so erode is filter you searching for.Last edited by pandy; 1st Dec 2016 at 05:47.
	Hysteria seems to be working well (better then other sharpeners) but i still didnt get close
 SetMtMode(5,4)
 AudioDub(a,v)
 ConvertToYV12()
 Hysteria(strength = 2.0 )
 DeHalo_Alpha(rx=2 , ry=2)
 SeeSaw()
 TemporalDegrain(SAD1=600, SAD2=400, Sigma=18) *doesnt seem to help denoising very efficiently...
 nnedi3_rpow2(2, cshift="spline64resize", fwidth=1280, fheight=720)
 Does placing dehalo after hysteria counters the faded line distruction? Since it darkens them they are less affected right?
 result https://forum.videohelp.com/images/imgfiles/EzEomqA.jpg
 his https://forum.videohelp.com/images/imgfiles/duBEz7K.jpg
 it looks close only from afar if you zoom in just a bit there load of difference (one is 720p and the other is 1080p is because one is a screen shot and the other are from avspmod)
 his version has much smoother result (no noise or artifacts and softer and more exact lines...)
 were you able to scramble something up ?Last edited by zanzar; 30th Nov 2016 at 19:10.
	waifu2x does a pretty good job for upscaling anime, but the avisynth version is too slow to be useful (vapoursynth version is about 20-30x faster, but still only get <1fps)
 Something is messed up with the timestamps in your sample. Why don't you just cut a piece of the original source ? Why are you using VLC ?
	e.g. waifu2x "default" anime settings, no other filters except colormatrix
	Hysteria has lots of parameters you can play around with. And you can call it more than once. Something like this is getting a little closer:
 It's creating some dark edges where it shouldn't though. Like in the shadow beneath the sunglasses. That should give you some ideas.Code:LWLibavVideoSource("4.mp4") ColorMatrix(mode="rec.601->rec.709") Hysteria(strength=5.0, maxchg=20, lowthresh=15, highthresh=20) Santiag(1,1) McTemporalDenoise(settings="high") nnedi3_rpow2(2, cshift="spline64resize", fwidth=1280, fheight=720) Hysteria(strength=3.0, maxchg=20) Santiag(3,3) Dehalo_alpha(rx=3, ry=3, darkstr=0.5, brightstr=0.5) nnedi3_rpow2(2, cshift="spline64resize", fwidth=1920, fheight=1080) Blur(1.0)
 Are you aware that you can use Interleave() to view changes caused by a filter? For example:
 will let you easily switch back and forth between the video without Santiag() and the video with it. That, along with a screen magnifier, makes it easy to see exactly what a filter is doing.Code:Interleave(last, Santiag(3,3))
	well thanks i think it works i played with the script till i've got almost the same result
 AudioDub(a,v)
 ConvertToYV12()
 ColorYUV(cont_y=0, cont_u=0, cont_v=0,gamma_y=0)
 Hysteria(strength=4.0, maxchg=20)
 Dehalo_alpha(rx=3, ry=3, darkstr=0.3, brightstr=0.3)
 nnedi3_rpow2(2, cshift="spline36resize", fwidth=1920, fheight=1080)
 Blur(1.5)
 aWarpSharp(depth=14)
 i found that "Santiag" worsen the quality (dont know how to describe it with terms but here is a link where the first is without it and the second with)
 http://screenshotcomparison.com/comparison/192430
 of course its not the same sample you used but it looks like here specifically it doesnt help .... do you agree?
 how can i know when to use "Santiag" and when not? and any other things i should keep my eye on?
 here is the final result when the first is with the script above and the second is the one i am aiming for
 http://screenshotcomparison.com/comparison/192436
 any suggestions to improve it even more?
 also if i want to stay at 720p and not go up to 1080p how should the script look?Last edited by zanzar; 1st Dec 2016 at 12:24.
	Santiag() is an antaliaser. It smooths jagged edges. If you don't have jagged edges you don't need to antialias.
	jagabo any way to deal with the flickering that hysteria sometimes when a there is no black lines dividing but rather different color?
 http://screenshotcomparison.com/comparison/192747
 like in this image,she doesnt move but heir hair changes constantly in a flicking way (like hysteria cant desive weather he should darken it or not causing constant darkening and un-darkening...)
 script:
 Hysteria(strength=6.0, maxchg=26, lowthresh=15, highthresh=20)
 McTemporalDenoise(settings="high").
 nnedi3_rpow2(2, cshift="spline36resize", fwidth=1280, fheight=720).
 Hysteria(strength=5.0, maxchg=28)
 Blur(1.0)
 edit: i think the double call for hysteria is doing it ...
 edit:maybe shifting one hysteria() to after the 1080p upscale?
 i guess its hard for him to target stuff like this on lower resolutions
 sample includedLast edited by zanzar; 4th Dec 2016 at 16:05.
	Try increasing lowthresh to about 30. Use it in both calls to Hysteria. Experiment with different values.
  Trying to Restore anime lines, need help with avisyth scripts linedarkeningBy kairukun in forum RestorationReplies: 3Last Post: 25th Nov 2015, 15:20
  Encoding Script for official-upscaled HD AnimeBy Narutofreak1412 in forum Video ConversionReplies: 6Last Post: 6th Mar 2014, 18:21
  How do I make this anime video look so good upscaled from DVD to 720pBy Kyousuke in forum Newbie / General discussionsReplies: 35Last Post: 12th May 2013, 10:23
  [HELP] How to rip anime shows/series/chapters?!?By mooshimuushi in forum DVD RippingReplies: 13Last Post: 11th Nov 2012, 21:33
  Anime Series MKV helpBy cprebble in forum EditingReplies: 4Last Post: 24th Jan 2012, 09:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
