hi
here is one for the brain's![]()
i have a factory produced vcd, the right channel is bad, no sound, just a slight wine, the left channel is fine, i have seperated the audio from the video, now i need to know what program i would use to split the left & right audio & make a copie of the left audio, so i can make it the right audio, then join them together again. i know it won't be true stereo but it will have to sound better than just hearing the left channel through my stereo.
thank's much for any help!!!
Soundforge5 is doing this under Pan/expand .....
"OO"P3-1.4ghz Tualatin/Slot-T adapter/AX6BC/Matrox G-200 Marvel16mo/320Rams-133@100/SBLive oem/DR-CDrw 16X/Raceleader FF wheel/ 2 X WD Caviar 40G 7200 + Fuji 11G 5400 HDS/ Q71/Win98 top notch/DX9/DSL/and faith in a good pc setup...oo -
thank's
but anybody know of a program just a wee bit cheaper ?
that's a bit much to fix a $6.00 vcd :P -
get the try-out or....... browse the net......
Maybe Gwave can do that also...... No idea....
i understand
but the newest is V5.0f & all i can find for help is V5.0ebrowse the net
Remove Small Section of Center Channel from Stereo Track
By EmpireStrikesBack198 in forum AudioReplies: 14Last Post: 31st Jul 2011, 12:48 -
Stereo track with only one channel working
By Cyclope in forum AudioReplies: 2Last Post: 13th Jan 2010, 04:22 -
"stereo" file (two channel signal) - Surround or Stereo?
By zee944 in forum AudioReplies: 0Last Post: 4th Sep 2009, 05:53 -
Unwanted Dolby Sound Mixed In With 2 Channel Stereo Tracks.
By travelagent73 in forum AudioReplies: 0Last Post: 18th Aug 2009, 10:49 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33
