Hello. My old Sony mini DV camcorder was stolen. I want to buy a used one so I can transfer many years of home videos (mostly mini DV tapes) to my hard drive to edit and then burn to DVD. Does the quality of the used camcorder matter here or is the "quality" already established from the footage years ago?
I believe my PC has a firewire port. Any recommendations for editing software if I do in fact have functioning firewire that will take care of the capture ? Novice here, thanks for any help.
As long as you don't get any blocking errors in your ripped video, then it should be a 100% copy of the data on the tape. No matter the camera model used to transfer it to your computer. Should only really matter when you want to film something to begin with, then the video sensor and the optic quality matters. I've never done a DV transfer so can't help there.
Yes, the camcorder is just reading digital data off the tape and sending it down the firewire cable. As long as the camcorder is reading the tape correctly and the firewire port is working you should be able to get a perfect copy of what's on the tape.
Audio out of sync when capturing AVI from Mini VHS Tape
By AvocadoTech in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2016, 21:29 -
Need help with indexing/archiving AVCHD mini hdv tape
By Orion5150 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2015, 14:40 -
Capturing HDV off of a mini DV tape?
By Oakie88 in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2013, 11:43 -
Mini-DV tape to Blu-ray? Good or Bad?
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 3rd Dec 2012, 22:13 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52
