I've been searching the web for info on the newer versions of Quick Sync (Haswell, Skylake) and it seems very scarce to come by so I'm sharing some of it here
For those encoding at TU4 or less (Haswell, Skylake), have a look at this comparison to previous versions. Essentially, it looks like the newer TU4 is equivalent to the previous generation TU1
[Attachment 39712 - Click to enlarge]
Attached below is the whitepaper from Intel where this image was taken from.
Here is a newer article on Haswell performance:
https://www.missingremote.com/review/intel-quick-sync-examining-haswell-performance
The information at Wikipedia seriously needs to updated: https://en.wikipedia.org/wiki/Intel_Quick_Sync_Video
One thing I can't find, so far, is whether there are any differences in Quick Sync implementation between the IPG within the same generation.The eighth annual MPEG-4 AVC/H.264 video codecs comparison showed that Quick Sync is comparable to x264 superfast preset in terms of speed, compression ratio and quality (SSIM);[4] tests were performed on an Intel Core i7 3770 (Ivy Bridge) processor.![]()
For instance, what are the differences between the Intel Core i3-6300 and the Intel Core i7-6700K graphics/QS. Both have the same HD 530 graphics/core.
Will add more info soon...
Any help with corrections or additional info is greatly appreciated...![]()
Results 1 to 1 of 1
Intel's QS based, Skylake powered hevc encoder beats x265 says MSU
By sophisticles in forum Video ConversionReplies: 29Last Post: 30th Nov 2016, 00:40 -
Intel Skylake Review
By SameSelf in forum ComputerReplies: 0Last Post: 16th Mar 2016, 09:17 -
Do not buy a Skylake cpu
By sophisticles in forum ComputerReplies: 54Last Post: 19th Jan 2016, 18:49 -
Skylake-K Released and Benchmarked
By SameSelf in forum ComputerReplies: 6Last Post: 7th Aug 2015, 08:18 -
No fps info in h264: is losseless patching possible?
By noemi7 in forum Authoring (Blu-ray)Replies: 5Last Post: 22nd May 2013, 16:26
