I'm trying to convert a divx file in to a vcd .mpg and part way through it gives me a 'floating decimal point error'. I'm using TMPEnc, and I've tried the different templates: NTSC, NTSCFilm, and PAL. None of them seem to work. Could someone shed some light on this situation? Thanks!
RAMevy@ckhnet.com
I had that happen on the second half of a movie I was encoding using TMPEGnc Plus (2.53) with my template...
After trying several things, I reduced the bitrate by 100. It worked. If you are doing x(S)VCD this is a possibility, however if you are doing *standard* VCD I dont think that will help you. -
your divx file contains corrupt frames. Not that uncommon, try searchin the forums for 'floating decimal point error' to find the fix
Load AVI into Vdub 1.49, select Video > scan video stream for errorsOriginally Posted by ramevy
Now select video streaming and audio streaming. and save as, save out another movie2.avi and use that to convert
Your avi has bad frames... -
I pulled the divx file into VirtualDub and tried scanning the stream for errors. Part way through the scan i get this error:
Internal Error: MMX State Left on: T:\Projects\VirtualDub_Old\mail\videosource.cpp:11 01
Any ideas at what I'm doing wrong?
Thanks! -
Well like most programs, thousands of different errors generate either the same error message or one that only the programmer can understand, probably a debug message. But it does sound as if there is problems with the AVI
Try using "vdub-mp3-freeze.exe" download from grokster/kazza its a modified version of Vdub 1.4C this creates a log file of the bad frames at c:\
That can then be used to remove the bad frames.
DVD Maestro Entry Point Not Found Error
By criver in forum Authoring (DVD)Replies: 7Last Post: 9th Aug 2011, 11:42 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 17:47
