Hello
I'm just gonna get to the point. When I insert a video clip into premiere pro (mp4) premiere pro removes most of my audio (it leaves about 10 sec of audio in the beginning). I tried to convert it into mov but then it just plays my voice and not the gameplay audio in the background. This started happening recently and I don't know why. When I open the video outside Premiere it works perfectly. When I import other videos from exampe youtube no audio is removed. I use OBS to record by the way. Would appriciate it if someone helps me out![]()
Anyone who might be able to help will require more information (I do not use Premiere so this can be my only contribution)
Ideally you should upload a short sample video - 20/30 seconds- which includes both your voice and background gameplay audio.
But I would ask if you made any changes in your method of recording with OBS. -
Could you post a screenshot of your OBS settings (output - video) please?
If you are recording a fragmented mp4/mov (usually a good idea), it's possible Premiere is having trouble reading audio past the first fragment.
You sound like you are recording multiple audio streams (game+microphone). If Premiere still doesn't support multiple audio streams, you will have to extract the secondary audio stream(s) somehow (ffmpeg or XMedia Recode) and import them as separate audio-only tracks.
Adobe Premiere pro cs6 - more than 1 audio track
By bigbangnet in forum EditingReplies: 3Last Post: 24th May 2016, 20:04 -
MJPEG in Premiere Pro CS6 Has No Audio
By koberulz in forum Newbie / General discussionsReplies: 12Last Post: 9th Nov 2015, 06:20 -
Imovie, final cut pro, adobe premiere pro questions
By parker7d7 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Feb 2015, 03:46 -
Final Cut Pro X vs Adobe Premiere Pro CS6 for capturing/digitising DV
By danvideodiary in forum Capturing and VCRReplies: 11Last Post: 7th May 2014, 19:28 -
Flack audio output for videos in Premiere pro CS6
By Stears555 in forum Video ConversionReplies: 2Last Post: 12th Mar 2013, 21:09
