I got this machine out after a couple of years sitting around. Played a couple of discs just fine. Next day, it won't play, and the tray won't open to let me get the disc out.
Is there a way to remove the disc without destroying the player? I may want to repair it later, but first I want the disc.
Thanks!
There is usually a small hole in the disc tray or below it. Take a large size paper clip and straighten it, then push it into the hole about an inch or two and the tray should open.
If that fails, remove the top cover and see if the tray can be accessed that way. -
Thanks!
No pinhole on this one. Guess I'll have to break out the tools. -
Likely the o-ring that opens/closes the drawer has snapped. A rubber band can be used but a replacement,o-ring should be aquired. Also possible a plastic "finger" at the rear of the drive has popped out of position,this can happen if brute force was used to close the drawer.
.f4v files won't play in VLC or open in Handbrake
By GalaxyUnicorn in forum Video ConversionReplies: 1Last Post: 9th Jan 2016, 04:06 -
Philips 5990/37... No Disc Error! Is it dead? Your insight please!
By frieday in forum DVD & Blu-ray PlayersReplies: 0Last Post: 9th Jan 2015, 02:47 -
Philips player won't play HD
By PowerFalcon in forum DVD & Blu-ray PlayersReplies: 7Last Post: 4th Aug 2013, 21:03 -
New here - need help - Disc won't play on my basic dvd player
By thompson615 in forum MacReplies: 9Last Post: 21st Mar 2013, 13:14 -
Philips DVP5990 won't Play Entire AVI
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 12Last Post: 1st Sep 2012, 17:05
