I have this new Acer Aspire E 15 laptop.
I prefer to work in low-light conditions so that I can get a better view of the pixels on the display. However, the keyboard lights have this auto-shutoff about every 30 seconds, and that is very annoying. I would prefer to keep them on rather than shine a light on it.
I can toggle them On and Off with the Fn+F9
Does anyone know if there is a way to keep the keyboard lights always on?
Go to Control Panel->Windows Mobility Center. If you see anything there for keyboard backlighting, you might find timer settings in that.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
unfortunately, there was no section for the laptop keyboard lights. i guess i'm stuck with the keyboard lights turning off after 30 seconds of no key presses. its not that critical. oh well. thanks anyway.
From what I'm seeing on the Acer forum, you've already found the only options available ( Fn+F9 ).
Google is your Friend
copy same software installation from laptop A to laptop B ?
By vhelp in forum ComputerReplies: 9Last Post: 7th Oct 2015, 12:21 -
Needed: keyboard shortcuts for PotPlayer
By Harry B in forum Software PlayingReplies: 3Last Post: 8th Sep 2014, 15:31 -
Bios Question And Keyboard Message
By Mitterhouse in forum ComputerReplies: 3Last Post: 8th Feb 2013, 16:20 -
Acer Keyboard problem
By ahhaa in forum ComputerReplies: 4Last Post: 15th May 2012, 11:53 -
keyboard help urgent
By dnmnbg in forum ComputerReplies: 2Last Post: 3rd Apr 2012, 21:45
