Hello,
The VCR won't work anymore for some reason. It will power on and on the display I see flashing "d" letter below SP. Inserting the cassette will eject.
Does anyone have an idea about the problem?
Is there any moisture inside the vcr ?? The letter d should stand for dew
Inside the machine. -
Not that I know of. I've not opened it yet. However my place has been quite chilled inside due to weather.
If I open it, where should I look for moisture specifically?
Thanks -
Oh my goodness, I opened the top cover and now it's working
Many Thanks for your clue.. da dew
Not sure where the dew sensor is but I guess the chilled top cover might have caused the sensor go off?
Do you have happen to have the service manual by any chance or know where I can get it?
Panasonic VCR Settings
By Tafflad in forum Capturing and VCRReplies: 90Last Post: 19th Jan 2025, 15:55 -
VCR comparison Panasonic NV-FS200(AG 1980) VS Panasonic NV-HS1000
By JoseD in forum RestorationReplies: 32Last Post: 18th Apr 2016, 09:30 -
ID this VCR (Panasonic AG series)
By fmctm1sw in forum Newbie / General discussionsReplies: 4Last Post: 8th Nov 2014, 03:49 -
Panasonic ag-5260 (pal) vcr
By Quasipal in forum RestorationReplies: 11Last Post: 30th May 2014, 09:50 -
VCR won't take tapes
By llmercll in forum Newbie / General discussionsReplies: 10Last Post: 19th Oct 2013, 20:03
