The vob files contain everything. Assuming the first set are just the movie and no other "junk" you should be able to open VTS_01_1.VOB with a program such as AutoGK and it'll display the four audio streams. The third audio stream should be the commentary. The rest of the vob files in that set (VTS_01_1.VOB thru VTS_01_6.VOB) will be included automatically as they're really just one large file split into chunks. You could open VTS_01_1.VOB with MeGUI's file indexer and it'll extract the audio the same way.
If there's no copy protection on the disc you could open VTS_01_1.VOB with those programs directly. If there is copy protection, you'll have to rip the disc first with a ripping program to remove it.
I don't know why MakeMKV isn't ripping that DVD correctly. From memory when you open a DVD it lets you select the title(s) on the DVD to rip and if you select the movie title it should rip everything to an MKV. The title might just be a number (I can't remember as I haven't used MakeMKV in quite a while) but it'll probably be obvious which one is the movie if there's more than one.
Results 31 to 36 of 36
In MakeMKV you insert the disc, if you don't specifically select a particular titles it just rips the entire disc, all titles and all subtitles and all audio tracks as separate mkv files per title. I have no idea why the OP has complicated the process when it is very straight forward? I think there is a clue in one of his posts where he says "I do it by rote". I have a client that I service his computer and is like this and has all the functions he needs to do written down on separate cards like a cake recipe - basically he has no idea of what he is doing.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I don't like the tone of any of these remarks.
I am abandoning this project. -
It all started using Handbrake and getting only one audio track but you prefer two audio tracks (main +commentary), is that right?
Handbrake did it correctly, right? If it cannot choose two tracks at the same time, just encode it again, choosing other audio track, video could be setting deliberately crappy, like 60x20 or something to speed it up.
Then load both MKV's into mkvmerge and delete that crappy video track, so you'd get only one video and two audio tracks for your new MKV file. -
The tone of the remarks ?? You've gotten some really good advice, and it has been given in a very respectful manner.
I echo what theewizard said earlier: I don't understand what you are trying to do. If you want to backup a DVD, use DVD Decrypter, DVD Shrink, DVD Fab, etc. If you want to manipulate the files in order to extract something, then you need to be specific about your goal because there are quite a few specialty tools for things like subtitles.
You really shouldn't criticize the "tone" of the comments, especially when there hasn't been any nastiness. Doing so may make it more difficult to get people to help you in the future, should you need it.
batch demux video folder
By montevo in forum Newbie / General discussionsReplies: 0Last Post: 16th Jun 2016, 07:56 -
Set the current folder as destination folder and workfolder in a BATCH
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 25th Jun 2014, 08:58 -
Going mad trying to demux a TS
By twinaleblood in forum Video ConversionReplies: 16Last Post: 22nd Jul 2012, 13:54 -
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09
