AsfTools didn't work for me ( run time error )![]()
so is there any other way?
as far as I know (and I could be wrong) there isn't a joining tool yet
but if yoru just planning to convert them then you could use this method to conver them to DivX (or any other codec) that can be joined
http://www.bath.ac.uk/~ma9sjb/dvd/asf2avi.htm
or if your trying to make a VCD you could convert them all in TMPGEnc and then join the mpeg'syour pal,
Stinky
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57 -
best programs to join wmv from command line
By ziptip in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2008, 01:02 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 22:58 -
how can i join VC-1(WMV-3)files
By sumeshkri in forum Video ConversionReplies: 3Last Post: 26th Oct 2008, 00:21 -
Is there a way to join or merge WMV files?
By srauch in forum EditingReplies: 4Last Post: 8th Sep 2007, 16:39
