I have an xvid video file in mkv.
i've created chapters for this and muxed it into mkv.
i played this file with mpc-hc and i find that all the chapters are fine..(re re rechecked)
but when i try to split the file according to chapters with mkvtoolnix then the splitted output have 1 or 2 seconds difference.
why this is happening?
and also pls suggest a good splitter.!
Thank u very much. !
mkvtoolnix can only cut on keyframes. It's cutting at the nearest keyframes to the chapter points you set.
Editors that don't reencode can only cut on keyframes. This is an issue for players too. DVDs for example always have chapter points set on keyframes. There are very few non-reencoding editors that can cut on non-keyframes, and even those must reencode the cut GOPs. VideoRedo is such an editor but I don't know if it has an automatic cut-by-chapters option.
MKVToolNix chapters question
By RandmTask in forum EditingReplies: 1Last Post: 21st Jun 2016, 12:09 -
Used MakeMKV to get file, Now I am trying to use MKVToolNix to get chapters
By tambra77 in forum EditingReplies: 6Last Post: 2nd May 2016, 15:06 -
MKVToolnix does not SPLIT m4A files by CHAPTERS (srt)
By RedSkyRoad in forum EditingReplies: 6Last Post: 31st Jan 2016, 11:08 -
Q: MKVToolNix - Chapters and appended files
By markanini in forum Newbie / General discussionsReplies: 1Last Post: 17th Oct 2015, 09:40 -
MKVToolNix GUI - Splitting a file with multiple file parts added to it
By MisterNewb in forum EditingReplies: 5Last Post: 13th Sep 2015, 10:47
