  1. Hey, all...An advanced newbie question.
    Got a problem. I'm using TMPGEnc to try and encode an SVCD from a DivX. When I run the conversion (which takes nearly six hours for 45 minutes of video) everything appears to work fine. However, when I play the resulting MPEG 2 file back in WMP, I get no video OR sound. The progress bar shows that it's playing fine, but I get nothing. If I open the same file in the file player that came along with my ATI-AIW, I get video and audio just fine. However, when I burn it into an SVCD to play on my standalone player, it doesn't work. Again, I get no video or sound.
    I have PIII, 1GhZ, 512 Meg Ram, 160 GB, TMPEG Plus 2.53, DivX Codecs 4.11 and 5 installed.
    Thanks for any help!
    DrC
  2. Brand and model of your player?
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  3. It's a Panasonic...I don't know the model number right off the top of my head. It reads VCDs (both compliant and non-compliant). It's not specifically SVCD compatible, however, I have always been able to get it to play SVCDs (that were created from normal AVIs, rather than DivX AVIs) by re-muxing the file it with a Video CD MPEG1 Header.
    DrC
  4. Banned
    Jun 2001
    UK
    Try loading the AVI into Vudub, select video streaming, and audio streaming and saveas save out another movie2.avi, then use that for your conversion in TMPGENC
