Xmedia works well using software encode(libav),
but if I try to use intel QSV encode,
it dosen't look to work properly(on i7-2600k sandybridge/ Win10).
While the older version(3.3.4.8) cause error using QSV option, the version 3.3.5.8 doesn't cause error with same option.
It seems work well, but .....
If I use the Decoder settings H.264(Intel Quick Sync) and MPEG-2(Intel Quick Sync) on 3.3.5.8,
all CPU load are still nearly 100%, same encoding time as libaV and video quality is not acceptable.
Other tool like QSVEnc(http://rigaya34589.blog135.fc2.com/blog-category-10.html it's full japanese page.)
on same PC works well. The CPU loads about 20% and encoding time is less than a half encoding time.
I uploaded some sample file encoded by Xmedia and QSVEnc. see http://yuknak.com/Movie/index.html
Is there anyone who use Xmedia QSV option on i7-2600k?
Tell me the settings details.
Results 1 to 1 of 1
XMedia Recode
By Arthur_Ballsack in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2014, 05:30 -
xmedia recode
By MaxOne72 in forum Video ConversionReplies: 3Last Post: 7th Dec 2012, 13:09 -
Using Filters In XMedia Recode
By ganymede in forum Video ConversionReplies: 3Last Post: 12th Oct 2012, 17:59 -
Xmedia Recode help!
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2012, 12:36 -
XMedia Recode problems
By RaW D Coy in forum EditingReplies: 4Last Post: 12th Oct 2012, 12:15
