Hi
I could Transfer all my miniDV cassettes to pc successfully (with the given Quality). Now I'll do basic cutting and then convert them to a format which I would be able to use on following devices:
- TV Screen (Pal), streamed from NAS (Qnap TS253-A)
- IPhone 7
- Windows 10 PCs
Probably I also would like to burn a dvd later on from that file. Of course I'll keep the original dv-files, but I don't like to do the basic cutting every time again, so one original file and one compressed for all viewers would be nice for me. Disk Space is not that big problem, even it should be not bigger than necessary. Video Quality is even in original not really high end, just home made videos from Holiday, birthday parties and little children.
Which format would you recommend me? Mp4? mpeg2? Which resolution?
Thanks for advice.
Cheers
Lukas
Is it right, that the Resolution will be Standard on 360x480 (if I remember), which is half of original DV-Format. When my 65"-lcd-tv is playing that in original Format it is just very small, of course it can be displayed in 4:3 Format in full Screen with black borders right and left.
Or is it probably better to convert the Videos in DVD-Format 720x576 for better Quality on big Screens?
Thanks for help. -
Your PAL DVD should be standard 720x576 MPEG2. It's lossy enough without throwing away half the resolution.
Your viewing mp4s and your DVD-compatible mpegs should each be made independently from your edited timeline or a DV master of your edited timeline. -
Hi
You mean, I should do 2 converts, 1 for DVD with 720x576 mpeg2 and 1 for Streaming on tv with 360 x 480? But when why not just do the DVD Format? Original DV-Recording (uncompressed avi) I'll Keep of course uncutted. -
Yes, your conversions should be tailored to the purpose of the output.
I tend to like to stay with the native source resolution, so the mp4s should be 720x576 as well.
That said, many players do not like interlaced, non-square pixel files, in which case I would do a 1024x576 deinterlaced conversion for widescreen (16:9) or 768x576 deinterlaced conversion for fullscreen (4:3.) If smooth motion were vital to me I might deinterlace to 50fps rather than 25fps. That is dependent on both personal aesthetic preferences and player capabilities.
DVD is a little easier because DV standard pixel sizes and interlacing closely align with DVD standards. All you need to change is the codec (though many folks insist on making it more complicated.)
Converting a sample video file of any resolution to 13000x1080 resolution
By user321 in forum Video ConversionReplies: 6Last Post: 6th Jul 2015, 07:21 -
MTS to Compressed Format with Subs to Display Date & Time
By watsonaka in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2015, 06:01 -
Any way to get the video resolution for hundreds of MKVs in a list format?
By StumpedTechy in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2013, 09:38 -
Can I just save my dv video in a compressed format?
By ridethebike in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th Oct 2012, 01:28 -
Simple Program to Record Webcam in Compressed Format?
By Sound Asleep in forum Newbie / General discussionsReplies: 4Last Post: 27th Jun 2012, 08:47
