My Philips DVDR3576H/37 suddenly can't see one TV channel, my main local PBS station, channel 6. I has always received it before. A few days ago I thought it was slow to go to stations when I used the channel +/- button, so I did a scan. I don't know if that's what caused this problem, but from that point on, it won't receive that station. The scan should only affect which ones it goes to when you use the channel +/- button. When I push the 6, 6.1, 6.2, or 6.3, it apparently goes to that frequency, but the screen is blank. The unit is connected to an antenna in my attic. The connection goes from my wall outlet to a splitter, which sends the signal to the TV and the DVR. The antenna out on the DVR is connected to a VCR. I have unplugged the DVR and checked the antenna connections. The TV and VCR still see channel 6 as normal, but the DVR doesn't. Is it a glitch in its firmware? Philips does not appear to have that available anymore. What can I do? That is almost the only channel I watch.
Results 1 to 1 of 1
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 12:32 -
philips dvdr3576h player
By matthew1966 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 13th Feb 2015, 12:58 -
How to re-edit a single channel on DTS audio 6 channel
By maisawka in forum EditingReplies: 7Last Post: 26th Jun 2014, 11:55 -
converting 6 channel audio to 2 channel & putting 2 streams in a container
By qorda in forum AudioReplies: 3Last Post: 14th Jan 2014, 03:43 -
Converting 6 channel audio to 2 channel stereo- Help needed
By drashkum in forum AudioReplies: 2Last Post: 7th Sep 2013, 23:33
