Basically I have one source that is recorded from a transport stream and the others which are screenrecorded at close to 30fps and the transport stream I have 29.970 fps and I'm trying to mix the sources such as:
Now I've tried TDecimate on B,C,D, and E, but when I do so it doesn't match the first sources 23.976. I've also tried adding srestore to the end of each of their lines, but it tells me srestore can only be used once.Code:A=LWLibavVideoSource("file1.ts").AudioDub(LWLibavAudioSource("file1.ts")).DelayAudio(-.194).TFM().TDecimate().Spline36Resize(1280, 720) B=LWLibavVideoSource("file2.mkv").AudioDub(LWLibavAudioSource("file2.mkv")) C=LWLibavVideoSource("file3.mkv").AudioDub(LWLibavAudioSource("file3.mkv")) D=LWLibavVideoSource("file4.mkv").AudioDub(LWLibavAudioSource("file4.mkv")) E=LWLibavVideoSource("file5.mkv").AudioDub(LWLibavAudioSource("file5.mkv")) A.Trim(1578, 1787)+B.Trim(185, 894)+A.Trim(2498, 3423)+C.Trim(215, 2327)+A.Trim(5535, 17067)+D.Trim(296, 584)+A.Trim(20589, 37395)+E.Trim(221, 2882)
I've also tried adding the soruces together likeand thenCode:F=B+C+D+Ebut that tells me the framerate does not match.Code:F.srestore()
Does any one have any input that could possibly help with this?
Thx
You could try making them all the same framerate before doing anything else to them with an AssumeFPS(29.97)
I'm not sure exactly what you are trying to do, but "StainlessS" over in doom9.org has developed quite a few tools for automatically matching multiple copies of the same video so you can line them up and then make some sort of decision on which one to use. Here are a few threads, although you may want to do some more searching:
Choose the best frames from identical sources
SpatialAlign v1.0 : Spatial Alignment of clips
MatchFrames/LocateFrames v1.06
Range/Frame Replacement plug
Editing two footage from two different sources
By puncho in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2015, 00:11 -
best sources for oldies videos?
By mikehende in forum Newbie / General discussionsReplies: 14Last Post: 2nd Feb 2013, 08:16 -
Multicam; differend sources
By shorto in forum EditingReplies: 0Last Post: 27th Jan 2013, 04:25 -
Been a while, new technology for capturing (various sources)?
By CaZeek in forum Capturing and VCRReplies: 5Last Post: 28th May 2012, 14:03 -
Laptop battery sources
By ranchhand in forum ComputerReplies: 3Last Post: 4th Jan 2012, 06:56
