    Aug 2015
    Quebec, Canada
    Hello.
    I'm ripping some seasons on dvd (full DVD-9 no compression), I put the option to split at 1 gb the .vob files. But I noticed one things. Some DVD gave me this king of result:
    VTS_01_0
    VTS_01_1
    VTS_01_2
    VTS_01_3
    VTS_01_4 etc
    and some DVDs
    VTS_01_0
    VTS_01_1
    VTS_01_2
    VTS_02_0
    VTS_02_1
    VTS_02_2 etc
    like if the structure of some dvds is everything in one piece splitted OR episode splitted. Is there a way to obtain the 2nd result ? like episodic type instead of one big .vob splitted ?
    Kalemvar
  2. Originally Posted by kalemvar1 View Post
    If you have one like the first example and you want to come out like the second example, then no, not without some major work on your part. And then the original menus won't work as they did originally, also not without major work. You'd have to reauthor the entire thing.
    Now, if you don't care about making a functioning DVD with the episodes split as you asked, then PGCDemux can (usually) split the VOBs by episode. But that won't make a DVD. You might do that if intending to convert the episodes to a different format.
  3. Member DB83's Avatar
    Jul 2007
    Look at 'What is a dvd' at the top of this page. Your disks are not stored as 'one big vob' but are split and titlesets and vobs. The maximum size of a vob is .99 meg so you are getting exactly what is on the disk.
