For reasons that baffle me, Potplayer doesn't always create thumbnails for bookmarks — the kind which should be visible when invoking the bookmarks index using the H key. Though they are properly numbered and work fine, some bookmarks simply fail to generate these captured frames when created using the P key.
Bookmarks do arrear, though considerably smaller, in the Edit Bookmarks window and when thumbnails are specified for display on the Navigation Bar, but I assume these are not saved. Rather, Potplayer is generating them on the fly. It also appears that only a limited number of edits can be made in the Edit Bookmarks window before Potplayer becomes confused and displays an incorrect video's bookmarks, and eventually crashing.
Is there currently a limit on the number of bookmarks Potplayer can retain in a particular video, or system wide? Or is it something else I'm missing?
Thanks!
Michael
Results 1 to 1 of 1
Michael Linder
Currently facing Media Crimes charges
KMplayer vs. VLC - bookmark and unwanted installs
By shokan22 in forum Newbie / General discussionsReplies: 22Last Post: 20th Sep 2014, 11:21 -
daum.net potplayer vs dvbsupport.net potplayer
By Binyul in forum Software PlayingReplies: 1Last Post: 12th May 2014, 10:45 -
MkvToMp4 keep thumbnails?
By Ofek in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2013, 03:39 -
Linux video player w/ good bookmark support?
By Hoser Rob in forum Software PlayingReplies: 0Last Post: 7th Feb 2013, 12:59 -
flv thumbnails
By Kracov in forum ComputerReplies: 1Last Post: 19th Oct 2012, 02:12
