Hello, I have a problem with the PGCEdit, it is that my computer is 64bit with AMD A4 APU series, with 8GB RAM and with Gigabyte Motherboard (previously had 32Bits) and what happens when running the Tracer, there are times that the preview does not run correctly and freezes and no longer processes the remains of the codes as a playback will run. But as I say before I had my 32bit Windows and if it works without problems, I would like to know how to solve that problem. Help Please?! Thanx.
I'm the author of PgcEdit, but it's the first time that kind of problem is reported.
Also, I'm not sure I understand. What is hanging? The main window in Trace mode, or the preview? The preview is based on very old code, with parts written in assembler, and it may be the culprit. Unfortunately, I haven't written it myself, and I can't modify it. So, if it is the culprit, I suggest to simply disable it. (Or, if you really needs it, you can perhaps kill it with the Windows task manager when it hangs. The trace should continue normally.)
As far as I know, the code of PgcEdit itself should never hang due to 64-bit hardware, and anyway, I have no way to test it on a computer with your CPU.
Sorry, but I can't help much more.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV
FFMBC - problems converting to DNxHD 185 10-bit codec
By Benoit in forum Video ConversionReplies: 1Last Post: 18th Aug 2016, 00:43 -
MPC HC: 32-bit or 64-bit on Windows 7 64-bit
By flashandpan007 in forum Software PlayingReplies: 20Last Post: 22nd Jul 2016, 09:22 -
Lossless (10 Bit RGB 444) and (10 Bit YUV 422) Compression Codec's
By JasonCA in forum Video ConversionReplies: 62Last Post: 25th Dec 2014, 23:40 -
Multiple problems with Shadowplay and Virtualdub (64-bit)
By Sardaukar in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2014, 14:27 -
Some problems with PgcEdit
By walruss in forum Authoring (DVD)Replies: 2Last Post: 21st Jul 2013, 01:50
