Hi,
I have a problem with the last version (20th november) of XviD4PSP for MAC (version 10.9.5). It opens and crashes immediately.
All versions I downloaded since today were okay, this is the first time it happens, what can I do?
Here are the first lines of the report:
Process: XviD4PSP [2074]
Path: /Applications/XviD4PSP.app/Contents/MacOS/XviD4PSP
Identifier: com.winnydows.XviD4PSP
Version: 7.0 (323)
Code Type: X86-64 (Native)
Parent Process: launchd [207]
Responsible: XviD4PSP [2074]
User ID: 503
Date/Time: 2016-11-21 14:34:31.457 +0100
OS Version: Mac OS X 10.9.5 (13F1911)
Report Version: 11
Anonymous UUID: 44A106EE-0CA8-230C-C2FB-956B6F5F8252
Crashed Thread: 12
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Dyld Error Message:
Symbol not found: _clock_gettime
Referenced from: /Applications/XviD4PSP.app/Contents/MacOS/XviD4PSP
Expected in: /usr/lib/libSystem.B.dylib
Any suggestions?
Thanx
Just use an older version for now. THen later try a new version and see if it works.
https://www.videohelp.com/software/XviD4PSP/old-versions#download -
XviD4PSP 7.0.323 crashes for me as well, with the same error. Looks like something the developer should fix.
XviD4PSP 7.0.170 opens fine. -
GREAT!
Thanx a lot CASE! It works...
Before writing this post I tried 3 or 4 older versions but I always get the message "version expired", 7.0.170 is ok.
Thanx, thanx, thanx...
Oh yes, I know... It's not my Mac so I don't know exactly all the characteristics, but I suppose it's a 64 bit version.
Older versions of the software (for example 7.0.318) were for 64 bit too but they worked fine...
Need help for a startup video...
By fiolvb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2014, 12:41 -
startup disk names
By colmosiris in forum ffmpegX general discussionReplies: 3Last Post: 16th May 2014, 10:31 -
Handbrake crashes on startup
By sum_guy in forum Video ConversionReplies: 12Last Post: 21st Apr 2013, 10:22 -
xvid4psp crashes if denoise is enabled
By codemaster in forum Video ConversionReplies: 1Last Post: 30th Apr 2012, 16:40 -
Help please:Virtual VCR crashes on startup
By cgarai in forum Capturing and VCRReplies: 10Last Post: 11th Apr 2012, 14:53
