  1. so i'm new to gpu encoding and i tried the nvidia h.265 option in staxrip
    using default settings, i get this error:
    Error Encoding using NVEncC 2.07 x64
    Encoding using NVEncC 2.07 x64 failed with exit code: 1 (0x1)
    The exit code might be a system error code: STATUS_WAIT_1
    The exit code might be a system error code: Incorrect function.
    Selected codec is not supported.
    StaxRip.ErrorAbortException: Encoding using NVEncC 2.07 x64 failed with exit code: 1 (0x1)
    at StaxRip.Proc.Start() in D:\Projekte\VS\VB\StaxRip\General\Proc.vb:line 262
    at StaxRip.NVIDIAEncoder.Encode() in D:\Projekte\VS\VB\StaxRip\Encoding\NVIDIAEncoder.v b:line 82
    at StaxRip.MainForm.Encode() in D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 2231
    at StaxRip.MainForm.RunJobRecursive() in D:\Projekte\VS\VB\StaxRip\Forms\MainForm.vb:line 3460
    changing the decoder to nvencc (avcuvid native or cuda) i get this error:
    Failed to open input file.
    any help?
    Aug 2013
    Central Germany
    So you want to use NVEncC to encode to H.265; do you have at all hardware which supports encoding to H.265? Which model is your graphic card? You will need at least a third generation NVENC encoder chip on it.
  3. my gpu is gtx 960m. apparently it doesn't support encoding to H.265 according to a forum. bummer.
    thanks ligh.de
