How can I create just one single menu with the option after loading to either 'Play All' Chapters or select one of the Chapters I created. No matter what I try I always end up with two menus.
Well I just did a quick project to see what I could come up with. It seems that the most number of thumbnails per page is 8 (for stock templates, that is). So if you have more than 8 chapters, you'll have more than 1 page. I assume you only have 1 title imported?
Here's what I did:
1. Added my title and chapters
2. Selected "Create a menu based on a template"
3. Chose one of the menus that had 8 thumbnails. If I had more chapters than thumbnails per page, then more chapter menus would be added
4. Selected "Track Menu Only"
5. Selected "Display the Track 1 Menu"
6. Selected "Display the track 1 track menu"
7. Select "Track 1 Menu Settings" in the upper right corner
8. Click on "Use local settings for this track menu"
9. Click on "Restore default settings" then click OK
Hope this helps -
Thanks a lot Brainiac that worked well with a stock menu and that gives me a base to see if I can do that with my own designed one as the stock ones are not fully editable.
UPDATE:
I now have my own designed single menu and so thanks again Brainiac.Last edited by meridklt; 20th Nov 2016 at 19:26.
Single page menu for .TS files - Authoring Blu-ray ISO.
By Mickey79 in forum Authoring (Blu-ray)Replies: 18Last Post: 1st Jan 2024, 13:22 -
Intro video before menu - Authoring WOrks 5
By Arnold_Layne in forum Authoring (Blu-ray)Replies: 5Last Post: 18th Jan 2014, 15:12 -
Authoring Works 5: need help with motion menu
By romeon in forum Authoring (Blu-ray)Replies: 5Last Post: 30th Nov 2013, 12:36 -
TMPGEnc Authoring Works menu
By multitech in forum Authoring (DVD)Replies: 1Last Post: 3rd Oct 2013, 13:41 -
Authoring DVD from a single .mpg file problems - size 0 kb in VIDEO_TS
By Nimloth in forum ffmpegX general discussionReplies: 4Last Post: 21st Jul 2012, 12:23
