Hello everyone - I am trying to take Linux MPEG-2 TS (.ts) video files that I've used a program to pull from my Channel Master DVR+ and convert to some format without ANY loss in audio or video. Is this possible? Basically I have music shows recorded that I'd like to play on my WD TV, backup, and share.
The DVR+ uses a Linux operating system and I've used another program to pull them onto my PC. I'm able to play them on the PC but want these in a more "friendly" format considering they're virtually unplayable with all of the audio/video programs that I have. A lot of the shows I have saved are available online for download or purchase (illegally) but every one has a noticeable loss in video and especially audio when people try to smash them into 500meg files for sharing.
I do not care about file size at all. I'm only concerned with preserving 100% of the audio/video quality.
Any thoughts or help would be much appreciated.
Thanks!
Brett
Results 1 to 16 of 16
Have you tried remuxing the files using mkvmerge (part of mkvtoolnix) ?
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I'm a total noob.
It's giving an error when I click start muxing saying "--- Errors emitted by job 'merging to file "ACL - Ryan Adams - Jenny Lewis.mkv" in directory "C:\Users\Brett\Desktop"' started on 2016-11-19 16:56:43 ---No streams to output were found. Aborting." -
When you load the file into MKV and before you attempt muxing, what tracks are displayed. Normally you should see video, audio (maybe a couple) and possibly subtitles tracks.
Better still post a MediaInfo file report on the file. Use View TEXT and copy and paste report into your post.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Well to do a lossless encode would probably make a file ~10 times bigger. A file which would be even harder to play and not very friendly. Lossless H.264 would probably be playable on other devices if they could support the extreme bitrate.
Best option would be to just keep the MPEG2 and audio as is, and just swap containers. Like MKV which has already been suggested. Or take a potentially small loss and encode it with x264. -
Download xMedia Recode
Profile Custom
Format MP4
File Extension MP4
Open Video
Select / Highlight Video
Open Video Tab & select copy
Open Audio Tab & select copy
On the bottom set your output folder
Add to queue & encode -
There are literally no tracks displayed on the bottom. It shows my file name up top "source files" but the "Tracks, chapters..." has nothing.
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Format settings, Endianness : Big
Duration : 1 h 1 min
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -127 ms
Stream size : 198 MiB (3%)
Audio #2
Format : AC-3
Mode extension : D (dialogue)
Bit rate : 128 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Delay relative to video : 33 ms
Stream size : 56.7 MiB (1%)
Text #1
ID : 49 (0x31)-CC1
Format : EIA-608
Muxing mode : A/53 / DTVCC Transport
Muxing mode, more info : Muxed in Video #1
Stream size : 0.00 Byte (0%)
Text #2
Format : EIA-708
Stream size : 0.00 Byte (0%) -
Sorry I'm lacking on the terminology but what you said sounds like what I'm thinking in my head. Not wanting to "convert" to anything specific. Basically if i could just change the extension to something more usable (.mkv, .mp4, etc) without "converting" it that'd be ideal.
Not yet. I can get them to play myself since I have them on my DVR but I'm hoping to change these to a non-Linux version just to make it easier for the future when watching, sharing, backing up on computer vs DVR, etc.
I'm basically capturing these from a large antenna on the roof to a Channel Master DVR+ but as people with Directv/Cable know it's very hard to "back up" your DVR so that's basically what I'm trying to do... but not in some Linux format. If I could get them into a more friendly container I'd be able to share with others so they'd also have full quality music programs vs. the compressed stuff you find online. Everyone that shares music videos/concerts online does what they do to movies and compresses the hell out of them (very well i might add) but there is a noticeable drop in audio quality when listening on a large speaker setup vs watching/listening at the original/full quality so trying to preserve that for myself any other audiophiles out there. While I'm at it I'd like to just keep the video quality as well.
An hour long music program may by like 5-10gig but I could care less about that with the size that HD's are these days. -
Have ANY of these files(?) played ANYWHERE outside of the Channel Master?
Could you load the file into MKVmergeGui and make a screen capture of what is there so we can actually see what you are seeing? There is a free tool called snipping tool to do this or simply the Print Screen button on the keyboard and then paste as new image into Paint Shop Pro or Photoshop etc. Save as jpg and post.
I thought you might be running Linux on your PC, but your computer profile says windows 10. If you have mounted the Linux drive using Ex2Fsd and have copied the files to a Windows PC, try the Windows version of VLC to play them. Windows 10 doesn't come with an MPEG-2 decoder installed, but VLC has the necessary audio and video codecs built in, and has a good chance of working for playing TS files on a Windows 10 PC.
Linux uses an Ext* file system, but TS is a standard container file format. If the files from your DVR+ don't strictly conform to the MPEG-2 TS standard, that has nothing to do with Linux. The fault lies with Channel Master.
For what it's worth, I use Windows DVR software and TV tuner cards to record TV shows in TS format. I have a ton of recordings in TS format. Beyond playing these files with various software media players running on a Windows 7 PC, the built-in media players in both my TVs play them. So does the built-in media player in a relative's LG Blu-ray player.Last edited by usually_quiet; 20th Nov 2016 at 17:09. Reason: clarity
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Yes all my PVR's are all Linux based and record stock standard TS format either mpeg2 or mpeg4 for HD transmissions. No encryption in Australian TV transmissions so no problem transferring to PC or MAC using either the local brand Beyonwiz or Topfield or most Enigma 2 based units. The "name" brands of PVR's or DVR's like LG, Samsung etc all apply encryption
For MPEG2 TS files ProjectX is good for cleaning up errors or TSDoctor for either MPEG2 and mpeg4.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
x264 presets in lossless(?) conversion
By Juha in forum Video ConversionReplies: 18Last Post: 13th May 2016, 00:58 -
Avidemux mpeg trimming--is MPEG PS muxer really lossless?
By bluescrubby in forum EditingReplies: 4Last Post: 8th Jan 2014, 06:18 -
Lossless conversion with Handbrake?
By WBFAir in forum Video ConversionReplies: 69Last Post: 1st Sep 2013, 17:35 -
Lossless conversion of MP4 to AVI AVIDemux
By Dave2ic in forum Video ConversionReplies: 5Last Post: 26th Oct 2012, 10:59 -
Need to identify right config for lossless conversion
By alegator in forum AudioReplies: 10Last Post: 5th Jul 2012, 16:34
