    Aug 2014
    egypt
    hello
    i want help
    how to add blur in video
    USA
    What format (Codec) video? If it's a AVI type container, maybe VirtualDub with a filter like 'Blur more' or similar.
    Or maybe Avidemux for other formats with 'Gaussian convolution' or similar.
    With either editor you will have to re-encode.
    Aug 2014
    egypt
    mkv
  4. Mod Neophyte redwudz's Avatar
    USA
    I'd try AVIDemux.
    Aug 2014
    egypt
    Is it possible to explain the way to add blur in video with AVIDemux
  6. Mod Neophyte redwudz's Avatar
    USA
    I haven't used the blur filters in AVIDemux, but load in a sample video, set output format and
    you should see the filters menu. Look under 'Noise'.
    Try the different blur filters and settings.
    If you just want to blur a small part of the video, such as a face or similar, then it gets
    a bit complicated. Others will have to advise you on that, as I haven't done it.
    Aug 2013
    Central Germany
    Spatial or temporal blur?
