How can I remove all the ads which occur when loading KMPlayer ?
Most likely un-install it and do a custom install if it permits that and un-check any undesirable ads or similar 'extras'.
EDIT: I also saw this post in the comments section of the player on our 'Tools/Software' page.
Unknown if this works, but if all else fails...
"Make a Kmplayer portable with no ads:
- extract installer with 7zip.
- delete all the folders that start with $
- make a folder named Logo, place inside an empty file named Index.htm
- start Kmplayer and select to save setings to ini file."Last edited by redwudz; 17th Nov 2016 at 13:14.
KMPlayer, HD bitstreaming problem...
By totalz in forum Software PlayingReplies: 0Last Post: 28th Dec 2015, 21:41 -
Cant apply styles in KMPlayer
By aliensrock50 in forum SubtitleReplies: 8Last Post: 19th Oct 2014, 15:41 -
kmplayer 3.0.33
By snmn_9188 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2012, 12:20 -
Clean Install Of KMPlayer
By jdvideo in forum Newbie / General discussionsReplies: 6Last Post: 17th Jun 2012, 13:59 -
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 05:10
