The unsigned [EDIT: signed] bytes I am used to (aka __int8, char) have a range from -128 to +127.
https://msdn.microsoft.com/en-us/library/s3f49ktz.aspx
Not real good for video work.
Results 61 to 71 of 71
So raffriff, would you be willing to re-run your code using unsigned bytes (0 to 255)?
The test was run with unsigned bytes. I edited post #61 above to clarify.
In post #55, BYTE is a typedef (alternate name) for unsigned char; see Windows Data Types.
By the way I added a count of total errors to see how many colors were out by 1 or more. The answer was four.Last edited by raffriff42; 20th Feb 2017 at 03:13.
I compiled riffraff42's code from post #55 and added an error count and got:
And why are you guys testing from 1 to 254 instead of 0 to 255?Code:Colors tested: 16387064 Errors: 13821768 Maximum red error: 1 Maximum green error: 2 Maximum blue error: 1
If the error can be held to +/- 1 no matter how frequently it occurs, that's good enough for me. You're going to have that error when you use division with integers.
ISTR I was having trouble testing from 0 to 255 so I used 1 to 254 with no trouble. My rationalization was that in video, 0 and 255 are sync and are off limits. You can test from 0 to 255 if it works for you.why are you guys testing from 1 to 254 instead of 0 to 255? -
Ah, think I see what your problem was. If you ran a loop like:
the ending condition will never evaluate as true -- because when R1 increments from 255 it will wrap around to 0 rather than changing to 256. To get around that you need to do something like this instead:Code:unsigned char R1; for (R1=0; R1<=255; R1++) { // blah }
Code:unsigned char R1; unsigned char r; for (int r=0; r<=255; r++) { R1 = r; // blah }
ffmpeg/x264 RGB to YUV
By SameSelf in forum Video ConversionReplies: 40Last Post: 14th Nov 2016, 19:40 -
YUV/ RGB problem in Avisynth
By spiritt in forum Newbie / General discussionsReplies: 9Last Post: 6th Sep 2015, 05:31 -
is this YUV or RGB?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2014, 11:21 -
MENCODER: how to convert from YUV to RGB?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2013, 14:24 -
YUV 4:2:0 to RGB
By toshyuki in forum ProgrammingReplies: 15Last Post: 8th Oct 2012, 13:12
