I'm using a Windows 7 HP Computer to capture a video tape to my computer to transfer to DVD using the Dazzle DVC capture card . I'm playing the VHS tape on my Panasonic DMR-EZ485VK DVD/VHS combo unit. It is possible to connect an S Video cable directly to the VCR (via video output) and capture the footage? I'm having trouble getting the S Video source to show up in the Pinnacle software.
Any ideas on how to do this type of connect?
I think most combo units only output DVD through S-Video. Check the manual.
The manual says you can use the DVD Priority S-Video output for VHS. But that the DVD will take priority if you are also using the DVD player.
Should I replace my Dazzle DVC 100?
By Kocayine in forum Capturing and VCRReplies: 19Last Post: 30th May 2022, 02:36 -
Anytime I connect the HDMI cable to my laptop, the video freezes
By rhinebeck in forum ComputerReplies: 21Last Post: 25th Nov 2015, 20:13 -
Panasonic dmr-e100h & panasonic dmr e700bd recorders - disc release problem
By nanirdjeff in forum DVD & Blu-ray RecordersReplies: 1Last Post: 5th Apr 2015, 13:59 -
Cannot capture at 720*480 with dazzle dvc 100
By brian88 in forum Newbie / General discussionsReplies: 19Last Post: 19th Nov 2012, 09:39 -
Dazzle DVC 100 - Message to change to Standard Definition
By fhmesq in forum Capturing and VCRReplies: 0Last Post: 15th Jan 2012, 17:09
