Hello all
I have this nice, high-resolution MKV of a two-hour concert, and I want to trim it down into the single songs. It's a 33.1GB, 1920x1080 video, 29fps with 193kbps on video and audio, and it lasts 2 hours and 16 minutes. Although I have quite a mediocre computer setup, I could easily edit 1080p video before but this specific one has been a nightmare.
First of all, I tried just dropping the MKV into Vegas Pro and Premiere Pro, but they don't support MKV, so the next best solution was to convert to MP4/AVI. And this is when it became impossible. I tried mkvtoolnix and mp4box, took ages then crashed at like 10%. I tried Avidemux but it just crashed as soon as it tried to load in the Matroska stuff. I tried rebox.NET which finished, and seemed perfect, but it turned it had massive audio-sync delays and had way too many dropped frames. I tried a NCH Prism conversion but that turned out so bad it was crazy. Video to Video Converter was, again, dropping too many frames. MkvToMp4 took ages before crashing.
I thought maybe I could just trim it like it was. I tried Solveig Video Splitter and their separate AVI splitter, both seemed fine but had tons of dropped frames. I tried DVDVideoSoft's video splitter but it crashed from the massive file.
None of this worked, so I kept on researching. I found tools like Machete or MKV Cutter but I feel like it would be best to ask some people who know what they're talking about! Hopefully someone can suggest a software that doesn't cripple due to the massive file.
TL;DR: I have a 33GB 1080p MKV that I need to trim and no software will just convert or trim it. Are there any tools that can handle this even on a mid-range(-ish) setup?
EDIT: I've now managed to do it. Using Machete 4.4 worked really quickly with no dropped frames. Would recommend
I have handled 50 GB files with mkvtoolnix without problems. Maybe your file or even your hardware is broken? (Mkvtoolnix supports splitting, btw)
Time to read the documentation:
https://mkvtoolnix.download/doc/mkvmerge.html#d4e760 (same options available in GUI in the "Output" tab)
Why mp4? -
I have used Vegas every day for the past fifteen years. It will read anything if you have a codec for that video format installed.
However, if that is not possible, you can convert the MKV into either an lossless video format or into an uncompressed video by using ffmpeg. I do that all the time with video formats that people send me that won't go into Vegas. I do this all the time with MKV. The ffmpeg code to convert pretty much any video into uncompressed is this:Code:ffmpeg -i "my video.mkv" -an -vcodec rawvideo -y "output.avi"
Code:ffmpeg -i "my video.mkv" -an -vcodec huffyuv -y "output.avi"
Code:ffmpeg -i "V:\Trail Camera Tests\New Year\MFDC0544.AVI" -ss 0 -c copy -t 9.9166667 "V:\Trail Camera Tests\New Year\MFDC0544_1.AVI"
How do I convert 1080p 10bit mkv's to 720p 10bit?
By fighuass in forum Video ConversionReplies: 6Last Post: 19th Nov 2015, 01:34 -
Cut/Trim the first few second of MKV File
By jslegers73 in forum EditingReplies: 16Last Post: 24th May 2014, 22:51 -
How convert MKV file with different mkv LEVEL (5.1 to 4.0..)
By Nabucanezor in forum Video ConversionReplies: 19Last Post: 8th Nov 2013, 16:56 -
Play Full HD (20-30GB) MKV Files on my TV
By thealliance43 in forum Video Streaming DownloadingReplies: 19Last Post: 25th Feb 2013, 09:15 -
rmvb to mkv 720p or 1080p, but video file kind of slow motion, why?
By finalflick in forum Video ConversionReplies: 4Last Post: 14th Jan 2013, 22:26
