Hi there.. I ma having some real strange problems with tsMuxer.
Basically I record X Amount of video on my camera and it is saved in a series of .ts files. What I used to do is use tsMuxer to join those files, import into Adobe Premier and then edit away.. all good. After a while we recorded some more footage, but I am needed to reinstall tsMuxer.. but this time it is a new version. Now it joins fine but the resulting file in premier is really unresponsive. Like you press play and the audio plays but you have to wait ages, and in AGES for the video to update in the viewer. This used to be a near instant process last time I tried this workflow.
I have a number of these ts files and need to edit them, but I can not get them to work.. and I was wondering if it has anything to do with these new settings...
These options were not in it last time I used it.....
What exactly do they do and dose anyone know if I should have them ON or OFF or what settings I need to set? In this screenshot I have turned everything "on" as a test...
Thanks for any help! Got a lot of editing to do for work and total have no idea how to fix this!! hehe
Why are you using tsmuxer at all? If your camera is shooting spanned clips, Premiere normally should be able to identify and join them automatically, on import. This assumes you are properly loading the entire folder structure and not just individual clips. The "broken" nature of spanned clips is what allows them to play more responsively.
What camera are you using? -
It's worked for me on Sony, JVC and Canon camcorders. Can't recall if the GoPros worked as well.
yeah.. that dose work.. I think you need to import though the "media browser" built into the application... thanks man! This is a workaround and cuts out a processing stage.. cheers!
You can simply drag and drop the folder containing the media right into the project window. (It's not a "workaround," it's the way it's designed. Best of luck.)
Adobe Premier Elements 13. Cropping
By video32 in forum EditingReplies: 4Last Post: 9th May 2015, 13:32 -
How can I download Adobe Premier Pro CS6?
By JasonSabo in forum EditingReplies: 1Last Post: 23rd Apr 2014, 21:49 -
TS Files in Adobe Premier - Can't use but want to use
By OneVibe in forum EditingReplies: 4Last Post: 12th Jan 2014, 17:23 -
By OneVibe in forum EditingReplies: 8Last Post: 1st May 2013, 10:53 -
incompatible display driver with adobe premier elements 11.0
By godefroy in forum ComputerReplies: 2Last Post: 31st Mar 2013, 19:45
