Results 1 to 13 of 13
  1. Hi, Having problems with inserting the special caracter "eighth note" in order to do closed captions
  2. Ths question has been asked before over the years - here's a nice, simple solution:
    Originally Posted by SaferSephiroth
    ...I've never had a problem writing the musical notes "♪" & "♫" just by typing [Alt]+13 and [Alt]+14 respectively. Whenever I come across an .srt that is supposed to have those notes I merely open it up in notepad (yes, notepad) scroll down to the necessary line, correct the note, and presto, music notes...
  3. The extended DOS character set:
    https://en.wikipedia.org/wiki/Code_page_437
    The numeric values starting with the top row:
    0 - 31
    32 - 63
    64 - 95
    96 - 127
    128 - 159
    160 - 191
    192 - 223
    224 - 255
    In some programs you can get most of them by holding down ALT, typing the 1 to 3 digit number, then releasing ALT. I don't think this works in Notepad anymore though.
    <edit>
    You can get some characters in Notepad by holding down ALT, typing 0 on the numeric keypad, then the 1 to 3 digit number. But this doesn't work for most of the "non-printable" characters below 32. There is a workaround though. Open a DOS window and type ALT014 (or whichever number corresponds to the character you want) and press Enter. You'll see a ^N where you typed the character but the error message will display the character you typed:
    [Attachment 39534 - Click to enlarge]
    Use the Edit -> Mark menu to mark the ♫ character, and Edit -> Copy it to the copy/paste buffer.
    [Attachment 39535 - Click to enlarge]
    Then you can paste it into Notepad.
    Crap, it doesn't work for character 13 because it gets mapped to a carriage return (Enter). Even if you use a hex editor to set the value it will probably be interpreted as a carriage return by the subtitle renderer.
    <edit>
    Aug 2006
    Also, not every font includes all the special closed captioning characters. You must also make sure that the font used to display the captions includes the special characters that you need.
  5. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Works in my notepad ♪
  6. Originally Posted by netmask56 View Post
    Can't get it to work here on Win7 or Win10.
  7. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    What characters you get in DOS and notepad etc. depends on what codepage is active at the time. Mine uses 437 for dos and works fine but must use 1252 if I want to use filenames with ellipsis and em mark in them.
Name:	ScreenHunter_201 Nov. 16 01.48.jpg
  8. DECEASED
    Jun 2009
    Heaven
    Please, forget the 7-bit era and the whole codepage nonsense...
    just use Unicode, problem solved.
    Font = "Lucida Sans Unicode"
    Font = "Arial"
    Codepoints used: 266A, 266B
    P.S.: Forget "closed captions" as well
  9. Originally Posted by El Heggunte View Post
    How good is unicode support outside of software media players -- the players built into HDTVs or Roku, for example? Also, I can copy/paste the characters from a firefox to notepad (then save as unicode), but is there a way to type them in if you don't have easy access to a document from which to do that?
    hold down the ALT key, press and release Numberpad 1, press and release Numberpad 3, release ALT key
  11. Member Budman1's Avatar
    Jul 2012
    but is there a way to a them in
    Type them directly into what? Explained above, notepad, subtitle edit, dos all work differently on different pc's. Where do you want to type them directly?
  12. DECEASED
    Jun 2009
    Heaven
    That's why I also said:
    In other words, the O.P. should be using bitmap-based subtitles.
    Aug 2006
    The sorts of players Jagabo is discussing don't always support bitmap-based subtitles, or only partially support them. srt probably has the widest support of any type of subtitle.
    [Edit] I looked at the list of supported subtitle types for my mother's Blu-ray player. VobSub is supported for locally stored files, but DLNA streaming requires text-based subtitles.
