I dont understand.... Fair enough if you dont know the aspect ratio of an AVI then TMPGEnc changes it for you. But I do know that it IS 16:9 but it still changes it back to 4:3 !!!
I have saved and resaved the damn template so many times Ive lost count. Despite this the Source aspect ratio (Advanced) changes back to 4:3 and Video Aspect changes back to 4:3 Display. If I then change the settings back to 16:9 the encode is then in the correct aspect ratio. Big deal but this means I have to manually make this change for 12 files !!
In case I am encountering a quirck in my capturing I tried a ripped bit of DVD which REALLY IS 16:9 !!! Still same result from TMPGenc.
This has a further ramification, if a batch list is made up the first being set to enclode 16:9 source and display, the first one IS encoded 16:9 but the following ones MAGICALLY change to 4:3 (I found this out by demultiplexing and viewing the video stream in Bitrate viewer). A subsequent import into SpruceUp of this file results in an error.
YOu may need to go into settings, then the advanced tab. From there, look at the Video Arrange Method setting. In the past I have had to set it to either Center (Keep Aspect Ratio) or Full Screen (Keep Aspect Ratio) depending on whether I was making a SVCD or VCD.
Hope this helps!Light is faster than sound. Perhaps that is why some people appear to be intelligent, until we hear them speak. -
I am using Full Screen (keep aspect ratio 2), whichever option upon loading an avi to encode the Video settings still change back to 4:3 ...
You may need to change it AFTER loading the video file then try encoding.
Well, yeah, thats the point ! How am I supposed to batch these together ???
[/quote]If I then change the settings back to 16:9 the encode is then in the correct aspect ratio. Big deal but this means I have to manually make this change for 12 files !! -
TMPGENC should retain the settings you last used. you can also hit the save button to save your settings.
letmeinforgodsake,
No offence but this is getting repetitive
Like YEAH ! Thats the point !!!
[/quote]I have saved and resaved the damn template so many times Ive lost count. -
So if you load TMPGENc set it as you want, then do a batch convert ?
The settings are saving ? no read only on any ini files ?
I just done a quick test..
1 load AVI change settings to what I want, quit program
2 renamed CurrentCfg.tpr to movie1.tpr
3, load next avi changed settings for test, quit program
4, run batch conver, load both tpr's into list
Never used this batch convert, must be a easier way
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 07:53 -
Changing aspect ratio on an mkv?
By vato76 in forum Newbie / General discussionsReplies: 15Last Post: 14th May 2011, 11:11 -
Changing aspect ratio for WMV?
By vato76 in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2010, 10:27 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 13:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 06:40
