Results 1 to 11 of 11
Until you tell us something about your laptop how are we supposed to knowIs my Laptop not ok for this resolution?
You're laptop has 4K display? You have sufficient bandwidth to watch the videos in realtime? You have sufficient CPU/GPU power to decode the videos in realtime?
http://ark.intel.com/products/81015/Intel-Core-i7-4510U-Processor-4M-Cache-up-to-3_10-GHz
that is the info on your cpu
max res is 3200x2000@60fps
no 4k
as for the 1080p60
your bandwidth is getting throttled or your system is having problems decoding the video -
DSL, 16 Mb/s? Doubtful. Try http://speedtest.net to see what you're really getting. And just because you're getting 16 Mb/s from some server near you doesn't mean you'll get 16 Mb/s from Youtube's servers. Your ISP could even be downgrading speeds from Youtube to cut down on congestion.
Also, download some of the videos from Youtube and see if you can even play them smoothly locally. -
If you want to play 4K videos, you not only need fast download speed and a fast laptop, but you also need to be streaming from a site that can serve 4K video without interruption.
One other thing, and this may be the most important of all: you need to use the right software video player. There is a HUGE difference in performance between various software video players when attempting to watch 4K videos, either streaming or those stored on the hard drive (or SSD).
Vegas makes my videos look red ish
By rocco123 in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2015, 13:30 -
Youtube videos
By tbwktm in forum Newbie / General discussionsReplies: 5Last Post: 12th Oct 2014, 07:09 -
Need no lag capture card to play xbox one on my pc with no lag
By joeyiswhammo in forum Capturing and VCRReplies: 6Last Post: 31st Aug 2014, 11:41 -
Playing Videos Makes PC Reboot
By jeanpave in forum Software PlayingReplies: 22Last Post: 5th Jan 2014, 01:44 -
Need help with YouTube videos
By alray1989 in forum Newbie / General discussionsReplies: 2Last Post: 4th Sep 2012, 15:13
