hi I have a video that is in another language so I want to add subtitles to it.
However, I wish the subtitles "embedded" , so that it will be universal and won't need another subtitles files that make things less convenient.
My question is
1. What is the most simple way to do it? I have no knowledge about all these things. Nothing fancy is needed but as long as practical and functional it's OK.
2. Would it consume too much CPU usage during the process? Since my CPU has higher power rated than my motherboard could support. The motherboard support hotline advised me not to do any intensive task to avoid overheat. Is adding embedded subtitles an "intensive" task
What format is the video file?
What format is the subtitle file?SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
If your subtitles is in suprip (.srt) format you could use Vidcoder
https://forum.videohelp.com/threads/364372-How-to-easily-burn-in-hardcode-srt-subtitles...-with-VidCoder
and set the priority to "low"
When you say embedded do you mean
Burnt in ?
or
Switchable via the remote like in a mkv or dvd format?SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
Please advise a freeware to create embedded subtitles
By kenny1999 in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2016, 06:12 -
Can browsers play embedded subtitles in WebMs?
By homo sapiens in forum SubtitleReplies: 1Last Post: 29th Jan 2016, 04:04 -
changing embedded subtitles timing
By aruwin in forum SubtitleReplies: 3Last Post: 8th Sep 2014, 00:56 -
Ignore the default embedded subtitles
By beycan in forum SubtitleReplies: 2Last Post: 28th Nov 2013, 21:19 -
embedded subtitles on avi file not displaying on TV
By frannybyrn in forum SubtitleReplies: 2Last Post: 26th Aug 2013, 09:45
