First of all, I know next to nothing about h/x265 (HEVC). I've done some h/x264 encoding though.
h265 encoding is available on my Intel Core i3-6300 HD 530 (Skylake) so I can provide some testing for those interested in how it performs.
The clip is a Bluray source (Game of Thrones Season 5 Episode 6: Bluray -> makemkv -> mkvmerge (to trim clip)
Other source files can be found here:
http://www.digital-digest.com/movies/index.php
Unless otherwise stated, I use the following script as a starting point:
I use StaxRip 1.3.7.0 (which came with QSVEnc 2.51) for the encoding.
I downloaded and extracted QSVEnc 2.58, then copied the necessary files to StaxRip -> Apps -> QSVEncC folder (rename existing folder and create a new folder with the same name so you can easily revert back to the original with reinstalling)
I can run tests on any clip suggested, only you must be able to provide setting I should use.
Results 1 to 20 of 20
Here is one test
S05-E06 - Unbowed, Unbent, Unbroken-cqp-18
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 401 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") #LoadPlugin("D:\Applications\_Music-Video\Video Converters\MeGUI 2624 x86 - 2015-12-05\tools\ffms\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") #deinterlace #crop #resize #denoise -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --cqp 18:18:18 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken cqp-18.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken cqp-18.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken cqp-18_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode Constant QP (CQP) CQP Value I:18 P:18 B:18 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 5749 frames, 40.29 fps, 4852.65 kbps, 138.71 MB encode time 0:02:23, CPU: 17.28, EU: 99.28, GPUClockAvg: 1095MHz frame type IDR 1 frame type I 24, total size 1.65 MB frame type B 5725, total size 137.06 MB Start: 5:27:26 PM End: 5:29:51 PM Duration: 00:02:24 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken cqp-18.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 139 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 5:27:26 PM End: 5:29:51 PM Duration: 00:02:24 -
And another:
S05-E06 - Unbowed, Unbent, Unbroken-icq-18
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 397 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") #LoadPlugin("D:\Applications\_Music-Video\Video Converters\MeGUI 2624 x86 - 2015-12-05\tools\ffms\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") #deinterlace #crop #resize #denoise -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --icq 18 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken icq-18.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken icq-18.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken icq-18_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode ICQ (Intelligent Const. Quality) ICQ Quality 18 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 5749 frames, 37.60 fps, 3437.03 kbps, 98.24 MB encode time 0:02:33, CPU: 15.14, EU: 93.28, GPUClockAvg: 1102MHz frame type IDR 1 frame type I 24, total size 4.48 MB frame type B 5725, total size 93.77 MB Start: 5:15:58 PM End: 5:18:33 PM Duration: 00:02:34 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken icq-18.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 98.2 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 5:15:58 PM End: 5:18:33 PM Duration: 00:02:35 -
Thanks for posting. Nice complete details
, including log file with settings
Interesting that the CQP encode has no P frames, just I, P . Normally the CQP ratio for most encoders when using CQP encoding will be set - lower, higher, highest , so that the I frames (which are the key frames) will have the highest quality, then the P, then the B . But not all encoders behave the same way, there might be an optimal ratio for a given encoder
It' s just 2 encodes on 1 source, but so far, my general impression of the quality is that it's not that great, and the speed isn't that fast...I know you had it set on "best", but 30-40FPS for a GPU encoder...doesn't seem right. NVEnc doesn't have b-frames for HEVC, but it gets something much faster something like 250FPS on the HQ setting (and I assume lower quality). It would be nice if someone with a newer pascal card could post some comparisons so it can be quantified
(I'm just making some observations, not criticizing or anything. And I' m not asking you do perform and post a zillion encodes, it takes a lot of time and bandwith uploading)
But thanks again for posting
Cheers -
I think you meant B frames
I don't mind doing the work, if it helps me in the end.
Bandwidth: I have an unlimited plan, so I'm not concerned about that.
This test has default settings:
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 260 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --fallback-rc --cqp 24:26:27 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source)1.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken (Source)1.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source)1_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 4 - balanced Encode Mode Constant QP (CQP) CQP Value I:24 P:26 B:27 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 5749 frames, 68.83 fps, 515.95 kbps, 14.75 MB encode time 0:01:24, CPU: 33.95, EU: 99.49, GPUClockAvg: 1098MHz frame type IDR 1 frame type I 24, total size 0.51 MB frame type B 5725, total size 14.24 MB Start: 9:42:20 PM End: 9:43:45 PM Duration: 00:01:25 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken (Source)1.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 14.7 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 9:42:20 PM End: 9:43:45 PM Duration: 00:01:25 -
Yes thx for correction, it's no P-frames . Just I,B
Code:frame type IDR 1 frame type I 24, total size 0.51 MB frame type B 5725, total size 14.24 MB
This last test had a low bitrate ~517kbps using --cqp 24:26:27, if you wanted higher quality / filesize, you can lower the values (I'm not asking you to do that BTW)
This last one had no P frames either .
68 vs 40 fps, for balanced vs. best quality. But it's not the whole story, because higher bitates take longer to encode too usually, at least they do with software encoders -
First of all thanks, greatly appreciated.
Could you post what options Staxrip exposes for QS HEVC, so that we can help you choose the highest quality settings (the only test that's really important to most of us I would think).
Also, could you try some bit rate based encodes, but if you must use a quality based encoding mode try --la-icq for AVC and --icq for HEVC (--la-icq isn't implimented for HEVC yet, Kaby Lake will have it); --la-icq is the closest mode that is similar to CRF, --b-pyramid, --la-quality, --b-adapt:
https://github.com/stax76/staxrip/blob/master/Encoding/IntelEncoder.vb
You can read through the Staxrip source code, there's a ton of options for QS that will greatly improve quality. -
Here is another test:
As you can also tell is that the fps has improved somewhat, I was running Kodi on another screen before. Now I turned it off and I gain about 10fps @1080pCode:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 262 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --fallback-rc --cqp 15:17:18 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source)15.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken (Source)15.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source)15_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 4 - balanced Encode Mode Constant QP (CQP) CQP Value I:15 P:17 B:18 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 5749 frames, 86.88 fps, 5627.48 kbps, 160.86 MB encode time 0:01:06, CPU: 43.26, EU: 98.63, GPUClockAvg: 1101MHz frame type IDR 1 frame type I 24, total size 2.88 MB frame type B 5725, total size 157.98 MB Start: 10:31:35 PM End: 10:32:43 PM Duration: 00:01:08 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken (Source)15.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 161 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 10:31:35 PM End: 10:32:43 PM Duration: 00:01:08 -
VBR - 3000kbps
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 264 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --max-bitrate 30000 --fallback-rc --vbr 3006 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-3000.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-3000.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-3000_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 4 - balanced Encode Mode Bitrate Mode - VBR Bitrate 3006 kbps Max Bitrate 30000 kbps QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off Ext. Features PerMBRC encoded 5749 frames, 76.57 fps, 2432.71 kbps, 69.54 MB encode time 0:01:15, CPU: 33.05, EU: 85.46, GPUClockAvg: 1107MHz frame type IDR 1 frame type I 24, total size 0.95 MB frame type B 5725, total size 68.59 MB Start: 11:06:58 PM End: 11:08:15 PM Duration: 00:01:16 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-3000.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 69.5 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 11:06:58 PM End: 11:08:15 PM Duration: 00:01:17 -
VBR - 4000kbps
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 264 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --max-bitrate 30000 --fallback-rc --vbr 3985 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-4000.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-4000.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-4000_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 4 - balanced Encode Mode Bitrate Mode - VBR Bitrate 3985 kbps Max Bitrate 30000 kbps QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off Ext. Features PerMBRC encoded 5749 frames, 76.04 fps, 3480.66 kbps, 99.49 MB encode time 0:01:16, CPU: 33.41, EU: 86.36, GPUClockAvg: 1097MHz frame type IDR 1 frame type I 24, total size 1.44 MB frame type B 5725, total size 98.05 MB Start: 11:04:19 PM End: 11:05:36 PM Duration: 00:01:17 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-4000.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 99.5 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 11:04:18 PM End: 11:05:36 PM Duration: 00:01:17 -
VBR - 5000kbps
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 264 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --max-bitrate 30000 --fallback-rc --vbr 4998 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 4 - balanced Encode Mode Bitrate Mode - VBR Bitrate 4998 kbps Max Bitrate 30000 kbps QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off Ext. Features PerMBRC encoded 5749 frames, 76.34 fps, 4551.48 kbps, 130.10 MB encode time 0:01:15, CPU: 33.50, EU: 86.13, GPUClockAvg: 1108MHz frame type IDR 1 frame type I 24, total size 1.85 MB frame type B 5725, total size 128.25 MB Start: 11:20:10 PM End: 11:21:27 PM Duration: 00:01:17 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 130 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L5@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 11:20:10 PM End: 11:21:28 PM Duration: 00:01:17 -
VBR - 5000kbps
This is a modified version of the 5000 kbps clip I uploaded earlier.Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken (Source).avs File size : 264 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S05-E06 - Unbowed, Unbent, Unbroken (Source).mkv") -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 5749 source frame rate : 23.976024 source duration : 00:03:59.7810000 target frame count : 5749 target frame rate : 23.976024 target duration : 00:03:59.7810000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --la-quality slow --la-window-size 10 --ref 3 --gop-len 96 --b-pyramid --b-adapt --direct-bias-adjust --strict-gop --max-bitrate 30000 --qp-max 30 --qp-min 20 --qp-offset 2 --avbr-unitsize 100 --mbbrc --extbrc --mv-scaling 4 --weightb --weightp --level 4 --videoformat ntsc --colormatrix bt709 --colorprim bt709 --transfer bt709 --fallback-rc --i-adapt --vbr 4998 -i "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000a.avs" -o "E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000a.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000a_QSVEncC.bat" Adaptve I-frame insert is not supported on current platform, disabled. Adaptve B-frame insert is not supported on current platform, disabled. B pyramid is not supported on current platform, disabled. ExtBRC is not supported on current platform, disabled. Min/Max QP is not supported on current platform, disabled. WinBRC is not supported on current platform, disabled. Direct Bias Adjust is not supported on current platform, disabled. MV Cost Scaling is not supported on current platform, disabled. WeightP is not supported on current platform, disabled. WeightB is not supported on current platform, disabled. QPOffset is not supported on current platform, disabled. vidprm.mfx.CodecLevel value changed 4 -> unknown by driver cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 4 - balanced Encode Mode Bitrate Mode - VBR Bitrate 4998 kbps Max Bitrate 30000 kbps QP Limit min: none, max: none Trellis Auto Ref frames 3 frames Bframes 3 frames, B-pyramid: off Max GOP Length 96 frames Scene Change off Ext. Features PerMBRC encoded 5749 frames, 80.33 fps, 4871.60 kbps, 139.25 MB encode time 0:01:12, CPU: 38.10, EU: 88.59, GPUClockAvg: 1105MHz frame type IDR 1 frame type I 60, total size 5.53 MB frame type B 5689, total size 133.72 MB Start: 11:57:09 PM End: 11:58:30 PM Duration: 00:01:20 General Complete name : E:\My Videos - Rendered\S05-E06 - Unbowed, Unbent, Unbroken vbr-5000a.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 139 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 11:57:09 PM End: 11:58:30 PM Duration: 00:01:21
This time, instead of the defaults, I selected pretty much everything to see what would happen.
Looking at the log file you can see that many features have been disabled.
etc. -
As far as I can see, StaxRip doesn't hide/disable any features at all. That's one of the frustrating things about this; not knowing which setting can be adjusted that may or may not affect quality.
For instance, when you select the LA-ICQ preset, I don't know whether I should adjust the Maximum QP, Minimum QP, AVBR Unitsize, etc. All of them are available for selection, but do they make any difference? I don't know, so all I can do is set them, run a test and see if there are any changes.
You'd think that an application would disable features that aren't available based on other selections.
The QSVEncC help file only lists features available, but it doesn't say WHEN they are available or for which preset. I haven't read through the Intel Quick Sync Media SDK.pdf yet either.
Any help on finding what works and what doesn't would be greatly appreciated. Otherwise, it's trial and error.
I posted some samples on another post.Also, could you try some bit rate based encodes, but if you must use a quality based encoding mode try --la-icq for AVC and --icq for HEVC (--la-icq isn't implimented for HEVC yet, Kaby Lake will have it); --la-icq is the closest mode that is similar to CRF, --b-pyramid, --la-quality, --b-adapt:
Yes, I took a quick look at that, it looks like Visual Basic, haven't done any programming in a loooong time though.https://github.com/stax76/staxrip/blob/master/Encoding/IntelEncoder.vb
S02-E01 - The North Remembers CQP-I18-P20-B21
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs File size : 353 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S02-E01 - The North Remembers (Source).mkv") #Spline36Resize(1280, 720, src_left=0, src_top=0, src_width=0, src_height=0) Trim(1, 2874) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 2874 source frame rate : 23.976024 source duration : 00:01:59.8700000 target frame count : 2874 target frame rate : 23.976024 target duration : 00:01:59.8700000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --cqp 18:20:21 -i "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers CQP-I18-P20-B21.avs" -o "E:\My Videos - Rendered\S02-E01 - The North Remembers CQP-I18-P20-B21.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers CQP-I18-P20-B21_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode Constant QP (CQP) CQP Value I:18 P:20 B:21 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 2874 frames, 37.03 fps, 6957.69 kbps, 99.42 MB encode time 0:01:18, CPU: 25.79, EU: 98.82, GPUClockAvg: 1093MHz frame type IDR 1 frame type I 12, total size 2.10 MB frame type B 2862, total size 97.32 MB Start: 2:29:29 PM End: 2:30:49 PM Duration: 00:01:19 General Complete name : E:\My Videos - Rendered\S02-E01 - The North Remembers CQP-I18-P20-B21.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 99.4 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 2:29:29 PM End: 2:30:49 PM Duration: 00:01:19 -
S02-E01 - The North Remembers CQP-I17-P19-B20
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs File size : 353 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S02-E01 - The North Remembers (Source).mkv") #Spline36Resize(1280, 720, src_left=0, src_top=0, src_width=0, src_height=0) Trim(1, 2874) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 2874 source frame rate : 23.976024 source duration : 00:01:59.8700000 target frame count : 2874 target frame rate : 23.976024 target duration : 00:01:59.8700000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --cqp 17:19:20 -i "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers CQP-I17-P19-B20.avs" -o "E:\My Videos - Rendered\S02-E01 - The North Remembers CQP-I17-P19-B20.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers CQP-I17-P19-B20_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode Constant QP (CQP) CQP Value I:17 P:19 B:20 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 2874 frames, 37.47 fps, 9188.78 kbps, 131.30 MB encode time 0:01:17, CPU: 26.37, EU: 99.42, GPUClockAvg: 1096MHz frame type IDR 1 frame type I 12, total size 2.44 MB frame type B 2862, total size 128.86 MB Start: 2:31:52 PM End: 2:33:11 PM Duration: 00:01:18 General Complete name : E:\My Videos - Rendered\S02-E01 - The North Remembers CQP-I17-P19-B20.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 131 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 2:31:52 PM End: 2:33:11 PM Duration: 00:01:18 -
S02-E01 - The North Remembers CQP-I16-P18-B19
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs File size : 353 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S02-E01 - The North Remembers (Source).mkv") #Spline36Resize(1280, 720, src_left=0, src_top=0, src_width=0, src_height=0) Trim(1, 2874) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 2874 source frame rate : 23.976024 source duration : 00:01:59.8700000 target frame count : 2874 target frame rate : 23.976024 target duration : 00:01:59.8700000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --cqp 16:18:19 -i "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers CQP-I16-P18-B19.avs" -o "E:\My Videos - Rendered\S02-E01 - The North Remembers CQP-I16-P18-B19.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers CQP-I16-P18-B19_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode Constant QP (CQP) CQP Value I:16 P:18 B:19 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 2874 frames, 38.10 fps, 12592.36 kbps, 179.94 MB encode time 0:01:15, CPU: 26.52, EU: 99.15, GPUClockAvg: 1084MHz frame type IDR 1 frame type I 12, total size 2.86 MB frame type B 2862, total size 177.08 MB Start: 2:35:13 PM End: 2:36:30 PM Duration: 00:01:17 General Complete name : E:\My Videos - Rendered\S02-E01 - The North Remembers CQP-I16-P18-B19.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 180 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 2:35:13 PM End: 2:36:30 PM Duration: 00:01:17 -
S02-E01 - The North Remembers ICQ-20
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs File size : 353 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S02-E01 - The North Remembers (Source).mkv") #Spline36Resize(1280, 720, src_left=0, src_top=0, src_width=0, src_height=0) Trim(1, 2874) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 2874 source frame rate : 23.976024 source duration : 00:01:59.8700000 target frame count : 2874 target frame rate : 23.976024 target duration : 00:01:59.8700000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --icq 20 -i "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers ICQ-20.avs" -o "E:\My Videos - Rendered\S02-E01 - The North Remembers ICQ-20.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers ICQ-20_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode ICQ (Intelligent Const. Quality) ICQ Quality 20 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 2874 frames, 35.98 fps, 7146.32 kbps, 102.12 MB encode time 0:01:20, CPU: 25.03, EU: 96.42, GPUClockAvg: 1087MHz frame type IDR 1 frame type I 12, total size 2.83 MB frame type B 2862, total size 99.29 MB Start: 2:37:42 PM End: 2:39:04 PM Duration: 00:01:21 General Complete name : E:\My Videos - Rendered\S02-E01 - The North Remembers ICQ-20.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 102 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 2:37:42 PM End: 2:39:04 PM Duration: 00:01:22 -
S02-E01 - The North Remembers ICQ-19
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs File size : 353 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S02-E01 - The North Remembers (Source).mkv") #Spline36Resize(1280, 720, src_left=0, src_top=0, src_width=0, src_height=0) Trim(1, 2874) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 2874 source frame rate : 23.976024 source duration : 00:01:59.8700000 target frame count : 2874 target frame rate : 23.976024 target duration : 00:01:59.8700000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --icq 19 -i "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers ICQ-19.avs" -o "E:\My Videos - Rendered\S02-E01 - The North Remembers ICQ-19.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers ICQ-19_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode ICQ (Intelligent Const. Quality) ICQ Quality 19 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 2874 frames, 36.28 fps, 8431.84 kbps, 120.49 MB encode time 0:01:19, CPU: 25.06, EU: 96.84, GPUClockAvg: 1101MHz frame type IDR 1 frame type I 12, total size 3.23 MB frame type B 2862, total size 117.26 MB Start: 2:41:26 PM End: 2:42:47 PM Duration: 00:01:21 General Complete name : E:\My Videos - Rendered\S02-E01 - The North Remembers ICQ-19.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 120 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 2:41:26 PM End: 2:42:47 PM Duration: 00:01:21 -
S02-E01 - The North Remembers ICQ-18
Code:-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- _________ __ __________.__ / _____// |______ ___ __\______ \__|_____ \_____ \\ __\__ \ \ \/ /| _/ \____ \ / \| | / __ \_> < | | \ | |_> > /_______ /|__| (____ /__/\_ \|____|_ /__| __/ \/ \/ \/ \/ |__| -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Environment -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- StaxRip x64 : 1.3.7.0 OS : Windows 7 Ultimate Language : English (United States) CPU : Intel(R) Core(TM) i3-6300 CPU @ 3.80GHz GPU : Intel(R) HD Graphics 530 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Source file MediaInfo -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs General Complete name : G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers (Source).avs File size : 353 Bytes -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- LoadPlugin("D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("G:\My Videos - Working On\GOT\S02-E01 - The North Remembers (Source).mkv") #Spline36Resize(1280, 720, src_left=0, src_top=0, src_width=0, src_height=0) Trim(1, 2874) -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Script Properties -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- source frame count : 2874 source frame rate : 23.976024 source duration : 00:01:59.8700000 target frame count : 2874 target frame rate : 23.976024 target duration : 00:01:59.8700000 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Encoding using QSVEncC 2.51 x64 -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- @echo off "D:\Applications (Exempt Sync)\$_64-bit\$_SystemBackup_2\StaxRip 1.3.7.0\Apps\QSVEncC\QSVEncC64.exe" --codec hevc --quality best --fallback-rc --icq 18 -i "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers ICQ-18.avs" -o "E:\My Videos - Rendered\S02-E01 - The North Remembers ICQ-18.hevc" cmd.exe /C call "G:\My Videos - Working On\GOT\AVS\S02-E01 - The North Remembers ICQ-18_QSVEncC.bat" B pyramid is not supported on current platform, disabled. cop.AUDelimiter value changed off -> auto by driver cop3.DirectBiasAdjustment value changed off -> auto by driver cop3.GlobalMotionBiasAdjustment value changed off -> auto by driver QSVEncC (x64) 2.58 (r1178) by rigaya, Nov 6 2016 21:01:07 (VC 1900/Win/avx2) OS Windows 7 (x64) CPU Info Intel Core i3-6300 @ 3.80GHz (2C/4T) <Skylake> GPU Info Intel HD Graphics 530 (23EU) 350-1150MHz [51W] (20.19.15.4416) Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17 Async Depth 4 frames Buffer Memory d3d9, 3 input buffer, 14 work buffer Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 24000/1001 fps Output HEVC main @ Level auto 1920x1080p 1:1 23.976fps (24000/1001fps) Target usage 1 - best Encode Mode ICQ (Intelligent Const. Quality) ICQ Quality 18 QP Limit min: none, max: none Trellis Auto Ref frames 4 frames Bframes 3 frames, B-pyramid: off Max GOP Length 240 frames Scene Change off encoded 2874 frames, 36.24 fps, 10692.62 kbps, 152.79 MB encode time 0:01:19, CPU: 25.62, EU: 96.78, GPUClockAvg: 1097MHz frame type IDR 1 frame type I 12, total size 3.60 MB frame type B 2862, total size 149.20 MB Start: 2:44:16 PM End: 2:45:37 PM Duration: 00:01:21 General Complete name : E:\My Videos - Rendered\S02-E01 - The North Remembers ICQ-18.hevc Format : HEVC Format/Info : High Efficiency Video Coding File size : 153 MiB Video Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main@L4@High Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Color range : Limited -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Job Complete -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=- Start: 2:44:16 PM End: 2:45:37 PM Duration: 00:01:21
is there any software support h265 converting via intel quick sync?
By cnzjs in forum Video ConversionReplies: 2Last Post: 2nd Mar 2016, 08:45 -
One computer streams HEVC H265 the other doesn't. Why?
By RaiderSteveO in forum Video Streaming DownloadingReplies: 4Last Post: 20th Jan 2016, 17:54 -
H265/HEVC encoder which supports alpha channel?
By Gyan in forum Video ConversionReplies: 5Last Post: 10th Jul 2015, 13:15 -
H265/HEVC samples
By deadrats in forum Latest Video NewsReplies: 51Last Post: 23rd Mar 2015, 01:15 -
Intel to release Quick Sync powered HEVC encoder soon?
By deadrats in forum Video ConversionReplies: 2Last Post: 3rd Jun 2014, 16:14
