  1. Hi, someone must be able to help?
    Maybe I'm thick or something, and it's staring me in the face, i'm trying to encode/compress a dvd using the robshots.com / doom9.org guide.
    I follow everything, Edit the settings as it says to, o.k out of the settings page, click encode, and create the .ecl file, but then what? i can't figure out what to do then, that is meant to take "hours" of encoding, and reduce the file size
    Sorry if its blindingly obvious, can anyone tell me?
    I'm using the 2.64 trial version if it makes a difference.
  2. no one got any ideas?
    It looks like cce has just created a .mpv file thats only 0 bytes in size.
    Tried changing settings, still no progress.
    No one else had this problem?
  3. I am experimenting with CCE,I am not an expert.
    If you got a mpv file you can rename that file to mpg and then you can be able to play it,..I did some test and the quality is great....to encode 2 minutes took like 11 minutes,wich is the avarage,I have just a pentium 566 mhz,32 video memory and 256 ram...
    good luck..
    Rigo.F
