  1. Hi,
    I have some files I have recorded uncompressed on a black magic hyperdeck though some video hardware encoders.
    I would like to calculate the PNSR from the original file that was played into the encoder (which started as a file).
    I need some way to easily match the frame of the file recorded on the black-magic....... then run the test...
    Any ideas?
    Thanks in advance
    Neil
  2. Originally Posted by themoog View Post
    Hi,
    Did you mean measure the PSNR of the uncompressed hyperdeck output file ? And the other video file is the "source" ?
    Is there a mismatch somewhere ? (e.g. where some frames cut off or edited, or did you play the file and didn't sync the hyperdeck) ? One way to match them would be to edit/cut the uncompressed output e.g. with vdub, then plug them into ffmpeg PSNR .
    The uncompressed v210 output of the shuttle is 10bit422, so very likely it wont give perfect PSNR values unless the source was also 10bit422 . For example, if the source was 8bit 4:2:0, the method and scaling algorithm of bit depth and chroma scaling come into play.
